Differential Trouble After Service - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By Hasan Shaikh
post #1 of 6 Old 2nd July 2018, 06:09 PM Thread Starter
lmurph
Hi All,
I purchased a 2007 E60 manual with about 90k miles a few weeks ago. On the test drives, everything ran flawlessly (total 30-40 miles of mixed driving). I did a PPI at an independent BMW specialist and the mechanic and I noticed the rear diff was leaking and I agreed he should replace the seals and flush with new fluid, which he did, using the SAF-XJ + FM booster.
Prior to the new fluid and seal replacement, the diff did not make any noise, but now it makes a telltale grinding sound reasonably frequently on slow turns at/near full lock. The mechanic advised me to do three slow circles in either direction, which I did to no avail. So a few days later I did 15-20 in each direction, which seemed to correct it for the rest of the drive, but it has since returned.
Having read some threads about this problem on here, I know the BMW TSB says it takes up to 600 miles for noise to go away, but my concern is that there was no noise before they worked on the diff and now there is. Plus lots of folks seem to report a previously noisy diff being fixed immediately when they changed fluid, let alone a diff that showed no issues.
Is it safe to drive on a noisy diff for 600 miles, waiting for the sound to go away? Should I have the shop redo the fluid change?
Thanks for any help or advice!
lmurph is offline
post #2 of 6 Old 2nd July 2018, 06:16 PM
AR424
AR424's Avatar
About a month ago I serviced mine with Red Line ShockProof Gear Oil, then went immediately to an empty lot and did 20 circles in each direction.....haven't heard a single sound out of the diff. I wouldn't feel safe driving a car with a diff that makes a 'grinding' noise, unless I knew for sure what it was and that it wasn't harmful!
There are some very knowledgeable guys here, I'm sure some will chime in soon.
AR424 is offline
post #3 of 6 Old 2nd July 2018, 07:37 PM
Dr.Dave.DDS
Dr.Dave.DDS's Avatar
When I got mine, it was doing the same annoying grinding sound at slow turns all the time. So I rellaced the fluid with the bmw one, per tsb and now it’s smooth as butter.
Dr.Dave.DDS is offline
post #4 of 6 Old 2nd July 2018, 07:38 PM
Dr.Dave.DDS
post #5 of 6 Old 2nd July 2018, 10:09 PM
flacoramos
flacoramos is offline
post #6 of 6 Old 3rd July 2018, 08:20 AM
Hasan Shaikh
Hasan Shaikh's Avatar
I would suggest you get the fluid level checked again and get it topped up if required.
Then do about 20 figure 8 turns somewhere safe. Do them at low speed and as tight as possible.
Hasan Shaikh is offline
PDC and Tire Monitor Trouble After Hooking up DDM DJ Auto Lights thenexlevel E39 M5 and E52 Z8 Discussion 0 27th May 2010 07:09 PM
Speedometer Calibration After a Differential Gear Upgrade RUFM5 E39 M5 and E52 Z8 Discussion 3 6th September 2007 03:44 AM
Is this normal? [Different noise from gearbox & differential after 2000km service] M-POWER 77 E60 M5 and E61 M5 Touring Discussion 8 9th September 2006 05:40 PM
Kill after Kill after Kill after Kill..... RaMsEs Most Memorable Threads' 44 16th July 2002 03:52 AM
