AC Needs Recharging? - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By de Witt
post #1 of 9 Old 1st July 2018, 03:10 AM Thread Starter
Derived
Derived's Avatar
Iíve seen some threads on here about loud AC compressors, but none seem to end up with a solid resolution, so I figured Iíd ask myself.
About 2-3 weeks ago, suddenly, I noticed that with the AC set to a fairly cold temperature, or at least a temperature much lower than the outside temp (if you live in Chicago, you know itís been sporadically very hot here this month) - I could hear a loud groaning sound that correlated exactly with RPMs and went away with the AC off.
Now, we did go from what must have been the longest winter in history (almost no spring to speak of, temps went from consistent 30-50 degrees to 70-80 almost overnight) straight to summer, so itís been a while since Iíve used the AC before the last few weeks. However, it never did this before. And, frankly, even during some of the warmer days in April & May when I was certainly using the AC (although not as heavily) - I did not hear anything at all. This seems to have been a sudden occurrence.
I have also thought lately that the AC could blow colder - I hadnít thought this before, but today, while driving around, even with the system set to max AC, it seems like I remember it being much colder even a year ago.
Iím wondering (and hoping) that this means it might simply need a recharge? As far as I know, this car hasnít ever had one, and itís a decade old now...so seems reasonable that this might be the case. However, the loud compressor also often seems to be a sign of failure, although it seems strange that for a purely mechanical part, it would suddenly become so loud and not gradually become worse & worse.
Will probably buy a recharge kit just to see, hoping that takes care of it. Thanks.
Sent from my iPad using Tapatalk
Derived is offline
post #2 of 9 Old 1st July 2018, 04:36 PM
sundaycruzers
If you donít remove the air from the system you will cause more damage to compressor, problem with diy from auto parts store is it just adds freon. so now the ac compressor has to compress something itís not designed to. these dyi recharge kits make repair shops tones of money. Just a FYI
sundaycruzers is offline
post #3 of 9 Old 1st July 2018, 07:26 PM
flacoramos
Err... what 'air' are you talking about? OP system has not been opened if that's what you're referring to. And what do you think the compressor was designed to compress? (Freon has been banned for 20+ years btw, but I get your point).
flacoramos is offline
post #4 of 9 Old 1st July 2018, 08:01 PM Thread Starter
Derived
Derived's Avatar
Iím hoping thereís not any air(atmospheric)...as far as I can tell there shouldnít be a leak of any sorts, although I canít confirm. Although in a pressurized system there really shouldnít be any even if there is a leak, right?
I will say, for the last 3 weeks that Iíve been noticing this...things havenít really progressed....the sound hasnít gotten worse, the AC temp hasnít gotten any warmer...AC systems have always seemed like black magic to me, is it reasonable for a system that needs to be recharged to change so suddenly? Thatís the only thing that worries me.
Derived is offline
post #5 of 9 Old 1st July 2018, 08:39 PM
de Witt
de Witt's Avatar
Take it to a reputable shop for UV leak test/proper recharge with the equipment that evacuates the system. The canned R134a kits you get off the shelf wont fix a fault with the AC system just pump in more refrigerant and oil (some have "stop leak" chemicals). The canned refrigerant added to the system will leak from bad seals, if that is the problem. If bad seals arent the problem, then adding more refrigerant (and oil) will be detrimental to the compressor.
I dont work on AC systems either, so this is something I always hand over to a shop. Worth every penny on 90F+ days.
de Witt is offline
post #6 of 9 Old 1st July 2018, 09:13 PM
flacoramos
In practice no. Technically yes due to diffusion across the rubber hoses etc. The proper way to recharge is to apply vacuum to the system, make sure no leaks exist, then recharge by refrigerant WEIGHT. Addition of oil depends on what's going on. I have NEVER seen any shop fill by weight so I tend to be skeptical. Most / all only hook up gauges and guesstimate by pressure readings.
post #7 of 9 Old 2nd July 2018, 01:23 PM
sundaycruzers
If your system is leaking freon what do you think replaces it?
Edit: r134a is a refrigerant just like r12 so both typically are called ďfreonĒ. And if the shop you go to doesnít use a scale to weigh r134a does that means their using cans? Not a true ac shop then, my shop uses hundreds of pounds of 134a a summer and every ounce is weighed...
Btw. You can still purchase r12 and itís still being manufactured.
post #8 of 9 Old 2nd July 2018, 03:54 PM
sundaycruzers
Itís not magic, it just need to be recharged. Sorry for running off the topic, everyone has basically told you the same thing. Have it professionally done by a reputable shop and you should have no problems for years or invest in the right tools to do it yourself with possible same result. DO NOT buy those ďdreamerĒ recharge cans from auto parts store, they are intended for short term use and can lead to system failure.
post #9 of 9 Old 8th July 2018, 12:38 AM Thread Starter
Derived
Derived's Avatar
Guys, thanks for all the replies.
I'm in the habit of doing the work on this car myself when I can...however I'm not sure what else one would need for a proper recharge...I've only ever seen people use the cans one might buy from an auto parts store, one with a pressure gauge to ensure proper filling, and that's about it.
If I had a leak, wouldn't I quickly be down to ~no AC at all? I suppose not if it was slow...but given that it's been nearly a month, with lots of AC usage in that time, it seems as if I'd know if it was leaking out at any sort of noticeable rate.
Derived is offline
k&n recharging kit OK to use on BMC filters? 2006whitem5 E60 M5 and E61 M5 Touring Discussion 7 1st December 2015 04:48 AM
E39 For Sale: AC Schnitzer Type 3 18x8.5 +15 18x9.5 +21.5 M5 specs! needs refinished, lightweight! Mycivicisfasterthanmym5 Parts / Other For Sale or Wanted 5 26th April 2012 01:46 AM
My AC fan is constantly on after charging my AC system. Rhino E39 M5 and E52 Z8 Discussion 4 31st March 2011 11:09 PM
Blinking AC Light and NO AC tutash E34 M5 Discussion 4 13th August 2007 06:13 PM
Recharging the remote key kinghurl E39 M5 and E52 Z8 Discussion 8 11th June 2004 02:53 AM
