Unstable on highway driving!!! - BMW M5 Forum and M6 Forums
post #1 of 7 Old 25th June 2018, 09:42 PM Thread Starter
DooRow_88
Recently I feel my car like floating/unstable while driving on highway past 80mph. What could it be? I was suspecting I need to replace FCAB but any other opinions? Car currently at 80,000 miles .
Mods : RPI SCOOPS , BMC FILTERS , BLOCK OFF PLATES , EISENMANN RACE EXHAUST/OVAL TIP , EUROCHARGED
DooRow_88 is offline
post #2 of 7 Old 25th June 2018, 09:56 PM
Brian Joitescu
Wheel balancing is often overlooked. Happened with my 2010 Camaro SS.
Brian Joitescu is offline
post #3 of 7 Old 25th June 2018, 10:30 PM
Waitingondapig
Waitingondapig's Avatar
Are your tires ( front or rear ) wearing quickly? My alignment was out on one of my other cars in the rear and it felt like it was floating all of the time till I aligned them. I suspect as the weight would shift when making slight steering adjustments, it would put more load on the other wheel and try to change the direction of the car slightly...the faster I moved the steering wheel back and forth, the worse it was.
2007 e63 M6 - All black
2008 e64 650i - All black
1998 e38 740il - All black
Seems I like black cars !
Waitingondapig is offline
post #4 of 7 Old 25th June 2018, 10:41 PM
Brian Joitescu
Yes, alignment 100%. That and a full road force wheel balance. The car will drive smoothly.
post #5 of 7 Old 26th June 2018, 01:19 AM
LordSaladbar
LordSaladbar's Avatar
Get the car on a lift or at least jack up the fronts and rears to try and inspect bushings. At 80mph, an M5 should feel planted. There are a lot of suspension pieces and honestly, the easiest thing to do would be to get under there and try and move some of the arms around or do a visual inspection. Torn control arm bushings could do that.
LordSaladbar is offline
post #6 of 7 Old 27th June 2018, 01:49 AM
liquid2
Is it just the front? The FCAB mainly feels loose in the front for me. I also have that on my list of maint to do.
liquid2 is offline
post #7 of 7 Old 27th June 2018, 05:15 AM Thread Starter
DooRow_88
Thumbs up
Thanks guys, Iíll definitely check my aligment and put on a lift to see if anything needs to be addressed.
M5 unstable idle? Dex1 E39 M5 and E52 Z8 Discussion 28 30th January 2008 06:24 PM
Unstable idling when car is started. M5Stalker E39 M5 and E52 Z8 Discussion 11 6th February 2007 12:47 AM
Unstable idling! Ahmed E39 M5 and E52 Z8 Discussion 5 29th January 2005 12:09 AM
