E60 M5 Engine rattle noise - BMW M5 Forum and M6 Forums
post #1 of 7 Old 20th June 2018, 06:28 PM Thread Starter
Daniel Dagnoni
Hello guys, this is my first post, I'm Daniel, from Brazil, I have a mechanic shop here and one of my clients brought an M5 with rattling noise.
After some research I decided to remove both chain tensioners for inspection and both seemed to have low oil pressure on them, the right side one had a little more pressure (and engine rattled more on left side).
I ordered new tensioners and my real question here is. can I just screw them on and star the engine? or do I need to turn engine mannualy, check timing or something else.
Learned a lot about these cars here but couldn't find any info on this.
Thanks a lot
Daniel
Daniel Dagnoni is offline
post #2 of 7 Old 20th June 2018, 06:48 PM
jcolley
jcolley's Avatar
Thanks a lot
Daniel
If you're talking about the timing chain tensioners, you can just replace them, but rarely do these fail on the S85 and cause rattle. Normally the rattle is in the VANOS cam drive gears as a result of low VANOS pressure or air trapped in the system.
jcolley is online now
The Following 2 Users Say Thank You to jcolley For This Useful Post:
Daniel Dagnoni (20th June 2018)
post #3 of 7 Old 20th June 2018, 07:02 PM Thread Starter
Daniel Dagnoni
I see, but since it was easy to remove the left side one I gave it a shot, I don't know about these engines, but it really felt like a failed part compared to others I'm used to.. so I went on and removed the second one and confirmed more pressure (less noise) on right side..
Car was not used for more than 2 years so I figured it could be the reason for failure on tensioners.
and it would be much easier to remove them than test VANOS pressure.. don't have many specific tools available for that in Brazil and dealers and indys are not used to lend theirs =/
also, VANOS readings on scanner were OK (angles and valves)
post #4 of 7 Old 21st June 2018, 01:15 PM Thread Starter
Daniel Dagnoni
If rattle continues, how can I bleed VANOS oil line to try to remove air in the system?
post #5 of 7 Old 21st June 2018, 02:43 PM
Pav
To bleed vanos you need software ISTA or DIS you can download it online if you search or simply buy cheap on ebay they will also provide Instalation instructions.
Pav is online now
post #6 of 7 Old 21st June 2018, 03:18 PM
Pav
If bleeding will not help get rid of this rattle next step would be checking vanos pressure , you can make build this gauge yourself. You will need hydraulic gauge up to 2000 psi on ebay this cost around £10 , hydraulic hose you can build and buy for around £20 just google it and double bunjo hollow bolt( make sure it can handle big pressure around 100 bar). Then check pressure I believe at idle no less that 70 bar but please do research. Name:  IMG_7878.JPG
Size:  1.07 MBName:  IMG_7880.JPG
Size:  994.7 KBName:  IMG_7886.JPG
Pav is online now
post #7 of 7 Old 21st June 2018, 07:20 PM Thread Starter
Daniel Dagnoni
Right, Thanks, I'm expecting tensioners to arrive between today and tomorrow.. hopefully it solves it.. if not I'll try VANOS, I have gauge like that, just need new tip with bolt! =]
E60 m5 rattle noise at certain rpm when engine under load Hg1245 E60 M5 and E61 M5 Touring Discussion 22 17th June 2019 02:35 AM
Engine Rattle Noise, Sounds Like Exhaust Leak Dan in Seattle E39 M5 and E52 Z8 Discussion 6 7th August 2016 09:26 AM
Whining engine noise, not the normal VANOS rattle seif_ossama E60 M5 and E61 M5 Touring Discussion 1 24th August 2015 01:52 PM
Pinking/Rattle type noise from engine area. plisken E34 M5 Discussion 6 5th November 2008 02:33 PM
Engine rattle noise on startup? Laidback E39 M5 and E52 Z8 Discussion 12 11th September 2006 09:19 AM
