Power Steering Pump Caused SMG Failure???? - BMW M5 Forum and M6 Forums
 2Likes
  • 1 Post By DRMCEO
  • 1 Post By jcolley
post #1 of 9 Old 19th June 2018, 04:42 PM Thread Starter
loud068
Last week on my way to work I suddenly got the transmission malfunction message with yellow cog. Car went directly into D and limp mode. I pulled over and turned the car off then back on, hoping it would reset things. Malfunction message went away and I got back on the road, however there was a massive delay when shifting into gears. I pulled over again and tried to power cycle the car and the car would not start at all. Had it towed to my indy and after diagnosing I was told that the power steering pump is going out and because it is linked to the SMG it caused the transmission malfunction. I have never heard of this happening. Has anyone else, does this sound legit? They want 2k to replace the power steering pump and I was told that he won't know if this caused damage to the SMG pump until after they replace the power steering pump....
loud068 is offline
post #2 of 9 Old 19th June 2018, 07:08 PM
iDev326
iDev326's Avatar
While both the SMG pump and the power steering pump use the same CHF-11S fluid, Iím highly doubtful the two systems are physically linked to each other. The SMG pump reservoir is on the transmission itself on the left side while the P/S reservoir is in the engine bay on the right side near the DME/electronic box. I canít recall any kind of line physically sharing between the two systems. Iíd ask your indy what kind of error codes/faults heís seeing and make a further diagnosis from there.
Sent from my iPad using Tapatalk
iDev326 is offline
post #3 of 9 Old 20th June 2018, 03:18 AM
pmalik
There's no physical connection between the SMG hydraulic system and the power steering hydraulic system.
pmalik is offline
post #4 of 9 Old 20th June 2018, 02:09 PM
sundaycruzers
Time to find a different Indy
sundaycruzers is offline
post #5 of 9 Old 20th June 2018, 04:52 PM
DRMCEO
I am no expert but, I don't see any relation to the two systems. I am waiting for JColley to chime in on this one. I call BS, but crazier things have happened.
DRMCEO is offline
post #6 of 9 Old 20th June 2018, 06:52 PM
jcolley
jcolley's Avatar
I did on his FB post. Absolute zero relation.
ISTA diagnostics say he has a faulty mechanic and needs to replace it.
jcolley is offline
post #7 of 9 Old 20th June 2018, 07:02 PM
DRMCEO
I am having a sale on E60 flux capacitors and can remotely replace them for 4 easy payments of 99.99 for anyone interested.
DRMCEO is offline
post #8 of 9 Old 20th June 2018, 07:15 PM
jcolley
jcolley's Avatar
jcolley is offline
post #9 of 9 Old 20th June 2018, 08:07 PM
DRMCEO
DRMCEO is offline
Power Steering Pump BRACKET Failure ard E39 M5 and E52 Z8 Discussion 14 24th August 2011 08:54 AM
2000 m5 Stalls caused by Fuel pump and relay sgou E39 M5 and E52 Z8 Discussion 10 23rd August 2011 10:14 PM
100 octane unleaded gas caused "Major loss of Power" avry8542 E60 M5 and E61 M5 Touring Discussion 26 1st September 2007 09:01 AM
E60M5 SMG Problems nearly caused an accident M5Phil E60 M5 and E61 M5 Touring Discussion 57 30th January 2007 01:44 AM
Dealer said shift kit (stabilizer bar) caused tranny failure. Ag02M5 E39 M5 and E52 Z8 Discussion 14 22nd April 2005 04:57 PM
