Nav - BMW M5 Forum and M6 Forums
 4Likes
  • 2 Post By RAYNOR
  • 2 Post By Skills
post #1 of 7 Old 15th June 2018, 07:17 PM Thread Starter
M5Jim
M5Jim's Avatar
Nav
I have a December 2005 build M5. After searching here and going through a bunch of youtube videos, I can't figure how to make my nav full screen, instead of in that small window on the side. I can't go back to the nearness display pulling into the garage after a long drive either, The M5 is running great and hasn't burned/used any oil in the last 1000 miles.
signed a new owner having the time of his life with the e60 M5,
M5Jim is offline
post #2 of 7 Old 15th June 2018, 08:05 PM Thread Starter
M5Jim
M5Jim's Avatar
Also another BMW owner said I should put the key fob in the opening on the steering column instead of keeping it in my pocket because it charges the battery in the key fob. Truth or Falsehood?
M5Jim is offline
post #3 of 7 Old 15th June 2018, 09:08 PM
RAYNOR
RAYNOR's Avatar
From everything I've read on the forum and elsewhere the key will not charge when inserted. I just replaced the batteries in all three of my keys. Literally takes 30 seconds. 2032 watch batteries which should be around $5 for a four-pack. You can youtube videos of how to disassemble the keys (it's very simple).
RAYNOR is offline
The Following 2 Users Say Thank You to RAYNOR For This Useful Post:
M5Jim (16th June 2018)
post #4 of 7 Old 17th June 2018, 05:25 PM
sundaycruzers
I’d love to know too, what I can tell you if you go to navigation then scroll to the bottom menu it will say map in direction of travel. That will give you the map in the larger and small screen simultaneously. I wound if a software update would if that. Or time to retrofit cic lol
sundaycruzers is offline
The Following 2 Users Say Thank You to sundaycruzers For This Useful Post:
M5Jim (19th June 2018)
post #5 of 7 Old 19th June 2018, 03:05 AM
Bimmer_Pilot
The full screen nav thing is actually one that has bothered a bunch of CCC nav owners since they came out. When the car is new it will display the nav fullscreen. The first time you use the split window it will initialize some code that cannot be undone and it will forever be in split screen. To this day no one has found how to reverse this.
Bimmer_Pilot is offline
The Following 2 Users Say Thank You to Bimmer_Pilot For This Useful Post:
post #6 of 7 Old 19th June 2018, 03:07 AM
Bimmer_Pilot
The battery in the fob is an NiCD watch battery. It is not rechargable like the diamond key cars.
post #7 of 7 Old 19th June 2018, 07:51 PM
Skills
You are stuck with the split screen in NAV mode for 2006 models. No full screen option exists while in NAV.
HOWEVER... You might want to consider the AVIN Android unit (or one by another manufacturer) which besides maintaining all the factory idrive capability, allows you to go full screen with their built in NAV or by hotspotting your phone and running WAZE or Google MAPs, or whatever you NAV app available in Google Play.
Way less expensive than upgrading your CCC.
Search the forum for a thread...
Skills is offline
The Following User Says Thank You to Skills For This Useful Post:
Online Source for NAV Update 22 Nav Update V22 (SW 3-1/63)? Rcl4668 E39 M5 and E52 Z8 Discussion 44 10th June 2004 03:37 AM
CD-Nav to DVD-Nav upgrade jbuccino E39 M5 and E52 Z8 Discussion 7 26th March 2004 03:55 PM
Dvd Nav System And Nav Tv sbsmith E39 M5 and E52 Z8 Discussion 4 20th February 2003 03:55 AM
Q: Does the MK-1 nav use the same wireing as MK-2 nav? 540is E39 M5 and E52 Z8 Discussion 0 22nd January 2003 05:44 PM
upgrading nav and screen software without nav system tfung E39 M5 and E52 Z8 Discussion 10 23rd June 2002 09:47 AM
