2006 M5 E60 will not start and hard/firm brakes - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By jcolley
post #1 of 4 Old 14th June 2018, 02:41 PM Thread Starter
Invest0rs
Registered User
Ladies and Gentlemen, I am having a heck of a time with my 2006 M5 E60. Back story. I few weeks ago, After the car sat for about 3-4 hours, I went to start it and it would not start. Along with this issue, the brakes were firm and could not be depressed. When trying to start, it sounded like the solenoid on the starter was engaging, but would not turn the engine over. No other noises were made. I suspected either a drained battery or a bad starter. Eventually, after trouble shooting, I had Advance Auto Parts charge the battery overnight (I had tried to jump it and also charged the battery at home to no avail), reinstalled the battery and everything worked. Chalked it up to a dead battery. Fast forward to 3 days ago. Exact same issue happened again. Verified Battery was good but this time it did not start. Exact same symptoms as far as hearing a click when trying to start it and the brakes are firm and will not depress. The only time the brakes are firm is when the car will not start. It has sat for a much longer time and the brakes are fine when trying to start, so I do not suspect there is any type of vacuum leak causing the brakes to be firm and not allow them to depress. If anyone has any idea what may be causing this, I would greatly appreciate some advice on what I would need to check/do to get this taken care of. Thanks in advance, Stacey
Invest0rs is offline
post #2 of 4 Old 14th June 2018, 05:55 PM
jcolley
jcolley's Avatar
You'll need to have the codes read to see, but I would be willing to bet there's an A0C5 code stored in the CAS module. Look for a bad or failing engine ground wire in the front right wheel well and loose plastic coated nuts on the positive leads in the engine bay (3 of them).
jcolley is offline
post #3 of 4 Old 18th June 2018, 01:31 PM
Hasan Shaikh
Hasan Shaikh's Avatar
The next time it happens try putting it in reverse gear and then bring back to neutral and then try starting.
Hasan Shaikh is offline
post #4 of 4 Old 18th June 2018, 02:34 PM
TexaZ3
TexaZ3's Avatar
Sounds like battery or ground issue.
E36 1999 M3 Coupe Dakar Yellow/Black Vaders
E36 2000 M Coupe Cosmos Black/Black Leather, Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein.
E39 2000 M5 Imola/Black Heritage
E46 2005 M3 Coupe ZCP Carbon Black/Black
E63 2006 M6 Coupe Indianapolis Red/Black/Madeira, Style 343
TexaZ3 is offline
E63 M6 For Sale: 2006 E63 M6 + WARRANTY 25k FIRM in 07020 warclok Cars For Sale or Wanted 2 30th March 2014 03:40 PM
E60 For Sale: FS: 2006 bmw m5 smg / dinan / 56k miles / warranty through 10/14 / black on black / $33,500 firm Timeless Cars For Sale or Wanted 6 3rd July 2013 06:22 AM
Changed front brake pads and bled lines - now pedal mushy, not firm - what gives? LarryTwohig E39 M5 and E52 Z8 Discussion 34 14th October 2011 12:25 PM
Brakes n Brakes for brakes v12 maniac E39 M5 and E52 Z8 Discussion 34 10th May 2011 02:41 PM
Brakes? Brakes... Brakes! Val E60 M5 and E61 M5 Touring Discussion 31 24th September 2004 06:05 AM
