Vanos adjustment unit question - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By Shanghai_todd
LinkBack Thread Tools Rate Thread
Old 14th June 2018, 03:03 AM Thread Starter
Shanghai_todd
I recently got a pretty bad oil leak between the vanos adjustment unit and mating surface to the head. Appears RTV was applied by the builder but has blown out and now leaks. My question is can the vanos adjustment unit be removed simply by removing the bolts on the front and lifting the valve cover or is there special alignment tools needed? Also is there a DIY or procedure anyone can share?
Shanghai_todd is offline
Old 14th June 2018, 01:45 PM
flacoramos
flacoramos is offline
Old 14th June 2018, 06:05 PM
jcolley
jcolley's Avatar
I haven't tried this, but I'm fairly certain it can be done.
- remove VANOS solenoids (to allow air in so pistons can be moved). Clean them and replace o-rings while out.
- remove valve covers
- remove all 4 bolts from actuator
- replace gasket
- reinstall bolts to actuator. You haven't released anything associated with timing and the swashplates, so it should go back exactly as it came out.
- clean old Drei-bond off of actuator mating surface
- apply new drei-bond per ISTA/TIS
- reinstall valve cover
- reinstall solenoids.
Who the hell uses RTV for that? It's a $14 gasket. Not very professional.
jcolley is offline
Old 15th June 2018, 01:47 AM Thread Starter
Shanghai_todd
Thanks guys, that TIS link is exactly what was needed. Took about 2h to tear everything down but I managed to get the unit out and now need to order the seal.
Good info in the Drei-bond and not mentioned in the TIS. Guess I need to order that also.
Rate This Thread
S85 Vanos Adjustment Unit Replacement DIY Question TZ04XJR E60 M5 and E61 M5 Touring Discussion 87 2nd October 2017 12:20 AM
Vanos Adjustment Unit wheresmycar E39 M5 and E52 Z8 Discussion 7 19th October 2015 03:45 PM
VANOS Adjustment Unit - Banjo Bolt aazeez1975 E39 M5 and E52 Z8 Discussion 9 18th June 2014 04:25 AM
Vanos repair question, camshaft adjustment? aquvist E39 M5 and E52 Z8 Discussion 24 8th July 2013 08:27 PM
Vanos Adjustment Units, Refurb-Parts List M5 London E39 M5 and E52 Z8 Discussion 18 12th October 2009 09:27 AM
