12v trigger wire in the trunk? - BMW M5 Forum and M6 Forums
post #1 of 10 Old 15th April 2018, 10:59 PM Thread Starter
MalibuMafiaV
I'm installing an amp for an aftermarket sub.
I need to know where a 12v trigger wire is in the trunk. Since the trigger wire for the logic7 system is the fiber optic cable... and well you can't use that lol.
I've got everything else wired up but this...
Help would be GREATLY appreciated.
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
Instagram
TheMalibuMafia.com
BMW E60 M5 Daily
And way to many to list
MalibuMafiaV is offline
post #2 of 10 Old 16th April 2018, 01:55 AM
AR424
AR424's Avatar
AR424 is offline
post #3 of 10 Old 16th April 2018, 02:02 AM Thread Starter
MalibuMafiaV
Originally Posted by AR424 View Post
Perfect!
Thank you. Is there install instructions included to where the trigger harness goes as well?
Instagram
TheMalibuMafia.com
BMW E60 M5 Daily
post #4 of 10 Old 16th April 2018, 06:56 AM
AR424
AR424's Avatar
AR424 is offline
post #5 of 10 Old 16th April 2018, 01:37 PM
cold m3
cold m3's Avatar
Check the fuse box on the right hand side. One of those fuses can be taped for trigger/power when the car is on only. (top row fuses)
Current: 6MT 2008 LCI E60 M5 (Interlagos Blue)
Last: 6MT Super Charged E46 M3 (Carbon Black) (6 years of ownership)
Instagram: Cold_M3
Photos of My ///M5
cold m3 is offline
post #6 of 10 Old 16th April 2018, 03:12 PM
Skills
Skills is offline
post #7 of 10 Old 18th April 2018, 10:25 PM Thread Starter
MalibuMafiaV
Is there a certain one you recommend on using? or any of the top row of fuses wires is fine?
This would be an option if I was going to use a trigger wire in the cabin. But I need one in the trunk only.
Originally Posted by Skills View Post
Since I never used the CD changer, I used the it's fuse for my QTP cutouts.
Instagram
TheMalibuMafia.com
BMW E60 M5 Daily
post #8 of 10 Old 18th April 2018, 11:47 PM
BadSeed
BadSeed is offline
post #9 of 10 Old 18th April 2018, 11:56 PM Thread Starter
MalibuMafiaV
Thank you!
Originally Posted by BadSeed View Post
I used #88 in the trunk for my exhaust valve. #87 or #88 should work for you.
Instagram
TheMalibuMafia.com
BMW E60 M5 Daily
post #10 of 10 Old 19th April 2018, 08:24 PM
carlos916
carlos916's Avatar
just tap into your trunk cigarette lighter wire, that way your amp wont be on unless you have the ignition on and wont kill your battery
carlos916 is offline
12V Accessory /switched power wire. whatheheck E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 26 21st April 2016 09:19 AM
12V (non-switched) wire /// dv/dt E39 M5 and E52 Z8 Discussion 9 13th April 2012 07:41 AM
+12V Accessory power wire / Switched 12V whatheheck E60 M5 and E61 M5 Touring Discussion 18 1st March 2010 03:15 AM
PDC Trigger wire, really stumped guys... TorqueDog E39 M5 and E52 Z8 Discussion 10 22nd February 2009 12:46 PM
iPod installation 12V wire jemmie E39 M5 and E52 Z8 Discussion 3 29th May 2007 03:56 PM
