ABS Bleed help - BMW M5 Forum and M6 Forums
post #1 of 2 Old 9th April 2018, 01:14 PM Thread Starter
secretchimp
ABS Bleed help
Hi All,
I had a bad ABS pump (diagnosed by two different shops). Replaced it with one rebuilt by BBA Remanufacturing. Swapped out the units, did a normal manual bleed, then did an ABS bleed using the INPA software. But when I restarted the car the brake pedal still went to the floor. Ran the bleed INPA program again - with same bad results.
Should I be doing something different with the software? Is there something I should run with DIS instead?
Any advice is greatly appreciated.
secretchimp is offline
post #2 of 2 Old 9th April 2018, 03:09 PM
Waitingondapig
Waitingondapig's Avatar
Originally Posted by secretchimp View Post
Hi All,
I feel your pain....so many places for little air bubbles to get caught in the ABS systems 😫
I havenít had to do my Mís ABS bleed yet from a part change out ( and hope to never, lol) so Iím not sure specifically for these cars, but for others I have done, I first did the manual bleed on the lines as normal ( like when you change a caliper or something ) then I had to cycle the ABS system using the software tool WHILE performing the manual bleed again. Did the manual bleed on all four then the manual bleed on all four while cycling the ABS module with the software.
This may be what you did so that info may not have helped though.
May be different for our cars though or others may know a better way in general, but it seemed logical that I had to open the valves in the ABS module while manually pulling fluid through the valves to ďpull ď any little bubbles out of the module.
My worry was that I would burn out the valve solenoids if I held them open for very long so I pumped up the vacuum bleeder, opened the valves with the software and open the bleed fitting, closed the bleed fitting and turned the valve off in the software. Repeated this several times to get all of the bubbles out.
2007 e63 M6 - All black
2008 e64 650i - All black
1998 e38 740il - All black
Seems I like black cars !
Waitingondapig is offline
Trying to bleed the ABS... Bwayahh E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 19th August 2017 02:40 PM
Transmission bleed: anyone know what this does m5rbk E60 M5 and E61 M5 Touring Discussion 6 27th October 2013 06:53 AM
Cannot access "ABS" section in INPA. Is this confirmation that new ABS module needed? dimi_108 E39 M5 and E52 Z8 Discussion 17 7th June 2013 07:22 PM
Rebuilt ABS module - fixed ABS and BRAKE lights - but DSC light still on. Codes inside absolutegtr E39 M5 and E52 Z8 Discussion 18 19th January 2013 07:12 PM
ABS Bleed M5 powered E34 M5 Discussion 7 29th May 2009 05:34 AM
