rod bearing, vanos replaced and yet...... still not working - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By azzy3915
post #1 of 6 Old 31st March 2018, 08:23 AM Thread Starter
henrymug
Just replaced the worn rod bearings, which is believed to be the root cause of some tiny metal debris running inside the system which caused engine lights on.
got the engine bottom cover cleaned and replaced with new engine oil.
yet, the follow fault messages are still lingering on, what else could have gone wrong? I seldom hear that oil pump and vanos oil pump need to be replaced due to low oil pressure.
besides, all 4 vanos steroids had been replaced 3 months ago including one of the throttle actuator motor replaced.
please help
ID:	859426   Click image for larger version
henrymug is offline
post #2 of 6 Old 31st March 2018, 01:11 PM Thread Starter
henrymug
henrymug is offline
post #3 of 6 Old 31st March 2018, 01:20 PM
old city bimmer
old city bimmer's Avatar
Did you replace the high pressure line from the vanos pump ?
"BMW 4 LIFE"
old city bimmer is offline
post #4 of 6 Old 31st March 2018, 05:52 PM Thread Starter
henrymug
nope, how does it matter?
the workshop is suggesting to replace the oil pump and vanos oil pump, but that's very expensive, and still no guarantee to fix the problem
henrymug is offline
post #5 of 6 Old 31st March 2018, 06:48 PM
azzy3915
I reckon it's high pressure vanos line it's very prone to corrode
Sent from my SM-G950F using Tapatalk
azzy3915 is offline
post #6 of 6 Old 31st March 2018, 08:08 PM
old city bimmer
The high pressure vanos line from the factory are prone to leak out. Your going have to open up the belly pan up again to change that hose. Google it - plenty of data on it to support your issue.
I would suggest to update the pump chain guide, sprocket,chain and vanos pump gear if its a pre 2007 model
"BMW 4 LIFE"
Rod bearing/main bearing. Types? ///M5 Touring E39 M5 and E52 Z8 Discussion 2 13th November 2017 03:59 PM
ECS tuning kit or BE Bearing set for rod bearing replacement? Sharpie12 E60 M5 and E61 M5 Touring Discussion 9 18th October 2017 03:45 AM
VANOS pump & Rod bearing Failure :( Please help! jpw0809 E60 M5 and E61 M5 Touring Discussion 7 28th October 2016 01:59 PM
Rod Bearing Tolerance? Rod Bearing Advice? lefebv19 E39 M5 and E52 Z8 Discussion 21 17th August 2011 04:36 AM
Problems w/Vanos system (After Vanos lise replaced) patq E60 M5 and E61 M5 Touring Discussion 10 23rd March 2006 08:42 AM
