OEM rod bearings vs Aftermarket Clevite rod bearings - BMW M5 Forum and M6 Forums
 3Likes
post #1 of 12 Old 29th March 2018, 07:06 AM Thread Starter
jolty43
jolty43's Avatar
At 65K miles, I am looking to replace my 2008 E60 M5 rod bearings soon. Generally, I am an "only OEM" guy. But since the rod bearings of the E60 M5 are one of the weak points of the S85 engine, I am inclined to go for the aftermarket Clevite rod bearings with added clearance and more oil lubrication. I'd love to hear some recommendations from anyone with knowledge/experience. Thanks.
jolty43 is offline
post #2 of 12 Old 29th March 2018, 09:15 AM
Hasan Shaikh
Hasan Shaikh's Avatar
Hasan Shaikh is offline
post #3 of 12 Old 29th March 2018, 09:23 AM Thread Starter
jolty43
jolty43's Avatar
Originally Posted by Hasan Shaikh View Post
BE Bearings with ARP BE Spec bolts. Thank me later.
Thank you for the reply.
How are the BE bearings better? More clearance? Better materials?
Have you had yours replaced with those? How long has it lasted you so far?
jolty43 is offline
post #4 of 12 Old 29th March 2018, 09:24 AM
Hasan Shaikh
This should answer all of your questions.
https://www.bebearings.com/
post #5 of 12 Old 29th March 2018, 09:27 AM
Hasan Shaikh
The BE bearings were still under development when I replaced mine. So I went with the WPC treated OEM bearings, which seemed to be the best option at the time.
If I have do it today, I will go with the BE bearings.
post #6 of 12 Old 29th March 2018, 09:56 AM
Bobbafett
Bobbafett's Avatar
Seconded
I'd go with BE bearings, replaced mine at the beginning of this year and for me, BE bearings where the only logical choice.
Bobbafett is offline
post #7 of 12 Old 29th March 2018, 09:57 AM Thread Starter
jolty43
jolty43's Avatar
Originally Posted by Bobbafett View Post
Seconded
Any noticeable difference when you drive?
jolty43 is offline
post #8 of 12 Old 29th March 2018, 10:37 AM
Bobbafett
Bobbafett's Avatar
Drives exactly the same as it did before
post #9 of 12 Old 29th March 2018, 04:10 PM
godnf8
godnf8's Avatar
OEM Bolts will work fine if you want to save a few bucks skipping the ARP BE spec bolts. BE Improved bearings are the way to go though
On a side note
- If you are doing this yourself, then ARP BE Spec bolts will save you a lot of time on retorquing since it's once and done, vs x3 for OEm bolts
- If you are going above basic bolt ons, then ARP BE Spec bolts wouldn't be a bad investment for forced induction or much higher horsepower on the motor, otherwise OEM will handle just fine
2008 BMW M5 E60 Current DD
godnf8 is offline
post #10 of 12 Old 29th March 2018, 05:21 PM
Fiftytwoeighty
Fiftytwoeighty's Avatar
I will likely go with BE bearings and ARP when I go in for my second set of bearings.
1st set of OEM went 84,000ish
2nd set of OEM are at 64,000ish
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =158,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; CKS coils w/swift springs, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Euro RestoMod track car: caged, 6 point FIA harness, FIA Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x8 BBS RK w/Dunlop StarSpec II; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is offline
For Sale FS: WPC Treated Rod Bearings w/ ARP Rod Bolt Kit - NIB Epacy Parts / Other For Sale or Wanted 1 12th April 2017 01:11 PM
Custom Clevite Rod Bearings for S65/S85 PencilGeek E60 M5 and E61 M5 Touring Discussion 49 8th March 2016 08:18 PM
Bimmerzone.com: BE Bearings - Improved Connecting Rod Bearings Set for BMW E60 M5 S85 Engine Bimmerzone.com M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 0 11th November 2015 04:19 PM
What aftermarket rod bearings Slawko E39 M5 and E52 Z8 Discussion 8 1st September 2012 10:40 AM
S62 engines - big end bearings/rod bearings sam1977 E39 M5 and E52 Z8 Discussion 2 27th October 2011 01:40 AM
