Throttle actuator gears where to buy - Page 4 - BMW M5 Forum and M6 Forums
 10Likes
post #31 of 38 Old 1st April 2018, 07:21 PM
AbdulM
Originally Posted by sundaycruzers View Post
Thanks for hijacking my thread! So far waitingondapig is the only person to answer my question. Frustrating that Abdul can’t listen to what I’m asking. I have brand new 30k ago bmw installed actuators and want them to last longer and would think upgrading the gears would do that, and don’t need to spend 700 after 2,800 already has been spent on actuators. All I want to know is who offers the best replacement gears. Please read before posting
Im sorry. I didn't mean hijack your thread. Lol. Gave a suggestions and others started asking questions. So accept my apologies. As the previous poster mentioned, it could possibly improve the longevity of the circuit board of your actuators if you change your gears. However, this has not been proven.
As for gears. There are so many cheap ones out there. Avoid them at all costs. Odometer gears are the best ones. Wherever you can find those, buy them.
http://www.odometergears.com/product...+E92+06-13/160
I also found an eBay buyer selling them. The buyers name is wd express. So check that as well.
Keep us posted on where you ended up buying gears from. Thanks buddy and apologies if I caused you any inconvenience.
Sent from my BBB100-1 using Tapatalk
08 E92 M3 (Alpine White)
00 E39 M5 (Diny's M5)
92 300zx Twin Turbo (Pearl White)
Sold:
E39 M5 (Silverstone Metalic)
E39 M5 (Carbon Black)
09 E60 550i (Dinan 5/M Package)
"Throttle Actuator Specialist"
AbdulM is offline
The Following User Says Thank You to AbdulM For This Useful Post:
sundaycruzers (1st April 2018)
post #32 of 38 Old 1st April 2018, 09:35 PM Thread Starter
sundaycruzers
sundaycruzers is offline
post #33 of 38 Old 2nd April 2018, 02:39 PM
Check_My_Six
I purchased my gears from an eBayer, i6 Automotive. It took several attempts to get a good pair that did not bind. In the end I like them, but it was a PIA to get them right. I'd not recommend the eBay items.
If one is able to replaced these "before" they start throwing codes IMHO it's a good move towards restoring gear wear.
Check_My_Six is offline
post #34 of 38 Old 2nd April 2018, 02:46 PM Thread Starter
sundaycruzers
Originally Posted by Check_My_Six View Post
I purchased my gears from an eBayer. It took several attempts to get a good pair that did not bind. In the end I like them, but it was a PIA to get them right. I'd not recommend the eBay items.
How hard was it to remove the shaft from actuators? Do you need a press. Seems like most kits require to remove the half gear in the actuator and some remove the gear and shaft combined.
post #35 of 38 Old 2nd April 2018, 02:48 PM
Check_My_Six
It took some work to remove the shaft from the housing ....a press is preferable. But, I did it without a press.
The Following User Says Thank You to Check_My_Six For This Useful Post:
sundaycruzers (2nd April 2018)
post #36 of 38 Old 2nd April 2018, 02:51 PM Thread Starter
sundaycruzers
When you say it took several gears, are you talking about the brass gear set or plastic gears?
post #37 of 38 Old 2nd April 2018, 03:28 PM
Check_My_Six
The molded plastic gears I received from i6 Automotive were not square with the shaft. There was a bit of wobble (run out) and rubbing. The company did work with me and sent another pair that I was able to get to work.
I do like the brass plastic combination. Plastic on Plastic....even if it's Delrin or glass filled ABS....is not the right material combination.
post #38 of 38 Old 3rd April 2018, 09:00 PM
Waitingondapig
Waitingondapig's Avatar
That was the one thing that steered me towards just replacing the gears on the OE shafts...that the little pressed on thick washer like retainer on the actuator arm side looked like a pain to remove and then press back on. Hitting the shaft end to get it out looked like an easy way to damage the motor or motor magnets from the shock of hitting it, so I would definitely used a small press or C- clamp to squeeze it had I gone that way. The other thing that made just replacing the gears more attractive was that I could reuse the OE shaft so I was assured that they were machined the right size for the pin bearings in the housing.
Once I looked harder at the ones that came with the new shaft, I also noticed that there appeared to be a set screw holding the half gear to the shaft ( I may be wrong though as I did not buy them and was only looking at the picture ). This seemed a bit weak vs the OE ‘molded to the shaft’ gear or the Odometer Gear setup that requires a hole to be drilled and the gear pinned plus the epoxy to fill up the voids and make it all tight.
Just a note, one does need to be careful not to remove too much metal from the shaft if replacing just the gear on the OE shaft as the video directions say. Making it too loose would indeed allow for the gear to not be perpindicular to the shaft and would probably rub for just replacing the gears as well.
As an update post gear swap...1200 miles now on my new gears....0 faults, the blinking 2 in the dash display when I shift to 2nd is now gone, and the engine now drops exactly to idle without the little rpm bobble it used to do. Maybe I caught it in time....maybe all of that ( other than the actuator fault and the limp mode ) is all in my head, lol
2007 e63 M6 - All black
2008 e64 650i - All black
1998 e38 740il - All black
Seems I like black cars !
Waitingondapig is offline
Throttle actuator gears replaced...Need actuator board LuigiRM5 E60 M5 and E61 M5 Touring Discussion 10 11th December 2018 12:19 AM
Which gears to choose for Throttle Actuator rebuild? Jomar1494 E60 M5 and E61 M5 Touring Discussion 26 5th October 2017 03:27 AM
Cheapest place to buy throttle actuator? adrigm6 E60 M5 and E61 M5 Touring Discussion 4 14th November 2015 02:09 AM
E60 For Sale: Actuator Gears New Bucky Parts / Other For Sale or Wanted 7 3rd August 2015 03:02 AM
where can i buy a rebuilt throttle actuator? iaintslow E60 M5 and E61 M5 Touring Discussion 3 6th June 2014 11:16 PM
