Doing my throttle actuators...anything else I should service while Iím there? - Page 2 - BMW M5 Forum and M6 Forums
 6Likes
post #11 of 16 Old 28th March 2018, 08:34 AM Thread Starter
Waitingondapig
Waitingondapig's Avatar
All done and back together, went flawless ! My gears were definitely shot and I can see why folks say when one bank starts faulting, the other will not last much longer. With my new flexible extension that maintains its shape, doing the clamps was simple...no more fears of getting frustrated taking off the plenums !
Interestingly enough, my 2 gear no longer blinks a couple of times as I shift from 1st to 2nd as it has done since I got it last year and the idle is also much smoother as well as less engine noise when idling. Makes me wonder if it was struggling to match the revs needed to shift normally and also throwing things off by the butterflies not being in the right position.
2007 e63 M6 - All black
2008 e64 650i - All black
1998 e38 740il - All black
Seems I like black cars !
Waitingondapig is offline
post #12 of 16 Old 28th March 2018, 01:03 PM
Racer14sl
Racer14sl's Avatar
Originally Posted by Waitingondapig View Post
I was debating on using Silglyde as it doesnít harden or stiffen over time. Think that will do it or is there something better for these movement points others have used?
That should work fine. As long as it doesn't dry up or harden after being exposed to heat.
2007 M5 SMG
Exterior: Silver Gray Metallic, Matte Black H-Style Front Bumper Splitter, Matte Black Euro Sport Front Grilles, 6000k 40W LED Halo Angel Eyes, Smoked marker lights, Smoked Tail Lights, 20" AC Schnitzer Type IV Magic Black wheels wrapped with Hankook Ventus Evo2 Tires
Interior: Indianapolis Red with aluminum trim, tinted glass
Mods: H&R Sport lowering springs, Tubi Style Rumore Exhaust, Primary and Secondary Cat Delete, RPI Ram Air, BMC Air Filters with block-off plates, RPI ST Pulley kit, FAMS tune
Racer14sl is offline
The Following User Says Thank You to Racer14sl For This Useful Post:
Waitingondapig (28th March 2018)
post #13 of 16 Old 28th March 2018, 06:44 PM
Jennifer-in-Seattle
Jennifer-in-Seattle's Avatar
Originally Posted by Sophie View Post
I would replace the pair of purge valves/vaccum control valves while there. The valves are prone to go bad and when they do, you will have annoying Gas Cap light on the dashboard and simply replacing the gas cap will not fix the issue. I would hate to bust everything open again just to replace them later on.
I am having this problem and was about to check the hose on the carbon tank in the rear wheel well for a lose hose. You don't happen to know the part number for this item do you, is it just one or two? Is there a DIY on this or picture some where showing where these are located?
Possible disregard on above, is this what you are talking about?
https://www.m5board.com/vbulletin/e60...valve-diy.html
Thank you
Jen
Jennifer-in-Seattle is offline
post #14 of 16 Old 28th March 2018, 08:23 PM
kei03174
Do your idle actuators and fuel purge valves while you are there the more you disassemble the plenum the more likely you will experience your EGR to run lean due to deviation or air intake you create while you open her belly. Technically every service involving plenum should better do it all at once to minimize the deviation set from the factory
In addition, i suggest you chnge the fuel purge valves hosed to the idle actuator. They are dc valve to open and close by DME and spring locking mechanism. When you have this valve aged, the valve got stuck open ever so slightly to cause you a great deal of headache. If your beast often driven only during the weekend and not dailied. The greater chane your valve can get stuck open.
kei03174 is offline
The Following User Says Thank You to kei03174 For This Useful Post:
post #15 of 16 Old 28th March 2018, 09:31 PM
Sophie
Thank you
Jen
Good find, Jen. This is what I was referring to. The part number should be 13907835364 and you will need two of them.
Sophie is offline
post #16 of 16 Old 28th March 2018, 09:36 PM
Jennifer-in-Seattle
Thanks Sophie....
https://www.ecstuning.com/b-genuine-...e/13907835364/
Jen
Throttle actuators problem M6sweden E60 M5 and E61 M5 Touring Discussion 9 7th September 2016 11:56 PM
Throttle actuators again Bucky E60 M5 and E61 M5 Touring Discussion 0 14th October 2014 01:27 AM
E60 For Sale: throttle actuators Tho///a5 Parts / Other For Sale or Wanted 5 31st January 2014 09:33 AM
E60 For Sale: FS: E60 M5 throttle actuators racinbmw Parts / Other For Sale or Wanted 2 15th November 2013 07:05 PM
E60 For Sale: M5/M6 Throttle actuators X2 gjs Parts / Other For Sale or Wanted 0 3rd December 2012 12:05 AM
