How to Setup Garage Door Opener - BMW M5 Forum and M6 Forums
post #1 of 7 Old 25th March 2018, 10:49 PM Thread Starter
godnf8
godnf8's Avatar
I had difficulty getting mine to work. Neither the BMW manual or Garage opener manual provided correct steps and had difficulty finding online (at least for me). Here are the steps that finally worked for me with 2 different garage openers.
****My car had to be started to work, not just ignition like manual stated. Keep in mind you will be opening and closing garage several times during this procedure, so you may want to park vehicle directly outside garage for this to avoid fume intake from exhaust. No good.****
1. (skip if you don't want to clear existing and just programming a second button for another function. If you do this for second function/button, you WILL WIPE your previous program.) Press left and right most memory buttons on rear view mirror and HOLD for about 20 seconds. The LED light next to memory buttons will flash rapidly notifying you all previous stored programs erased. Release both buttons
2. Press and hold the memory button you want to program until it flashes slowly and KEEP HOLDING
3. On your original garage transmitter (the remote with button to open/close garage) press button to open/close. IF LIGHTS FLASHED RAPIDLY you're done, it worked release any buttons you are holding, otherwise press the button on original transmitter again changing position keeping near mirror until you find sweet spot and get the rapid flash of LED lights. If the light goes off all together repeat steps starting at #2 as you hit the timeout. For me holding both buttons together (mirror plus original opener like directions stated) did not work, I had to hold mirror button continuously and randomly press transmitter button from different spots/angles near mirror until it sync'd
Alternating Code (Complete steps above first or this is useless, you need to give the car a code before it pushes anything out to attempt an open/close)
1. On Garage Drive (unit inside garage that opens and closes), press and release the memory/program button on back (mine only had one), once pressed the LED light next to it comes on solid
2. QUICKLY (you got about 30 seconds). Press the memory button inside car on rear view mirror you want to program 3 times quickly. This did not fully do it for me, after doing this 3 times quickly, press and hold the memory button for a second or two until it flashes rapidly and that will complete the cycle for the garage drive unit to accept code, light will go off on drive unit. I did this several times and until I did the long follow through at end by a 2 second button press on rear view mirror, the garage never took the button presses. Once I did do this, programming completed and worked fine. Now you should be all set and your garage should have probably opened and closed from the memory button on rear view mirror at this point.
2008 BMW M5 E60 Current DD
godnf8 is online now
post #2 of 7 Old 26th March 2018, 03:19 AM
Blackfox1225
Will try this later this week. I have been trying on and off for 9 months! I too had issues finding info online and everything I did find failed. Pretty sure I never did this with the car running and I never did the 3x press plus 2 sec hold combination.
Will report back later!
Blackfox1225 is offline
post #3 of 7 Old 26th March 2018, 04:38 AM Thread Starter
godnf8
godnf8's Avatar
Hopefully it helps! Also, try a different button. For whatever reason I couldn't get button #1 to work which I spent a couple hours on, but buttons #2/3 worked fine in half the time for both
post #4 of 7 Old 3rd September 2018, 02:13 PM
signalMTB
signalMTB's Avatar
Before you do anything, determine what model and year your garage door opener was made. If it’s a chamberlain or liftmaster and much past the year of the car, you need a Homelink repeater that plugs into an outlet in your garage. My 2008 M5 didn’t work with my 2014 Liftmaster. Tried for weeks with my M5 and Range Rovers and never worked. Plugged this in an instantly worked.
LiftMaster 855lm Homelink Repeater Kit
https://www.amazon.com/dp/B01GWD4LUI..._JusJBbZEGFXBT
Second Daily Curated Car Auctions, the new alternative at https://seconddaily.com and on Instagram and FB @seconddailyclassics
signalMTB is offline
post #5 of 7 Old 4th September 2018, 02:19 PM Thread Starter
godnf8
godnf8's Avatar
Originally Posted by signalMTB View Post
Before you do anything, determine what model and year your garage door opener was made. If its a chamberlain or liftmaster and much past the year of the car, you need a Homelink repeater that plugs into an outlet in your garage. My 2008 M5 didnt work with my 2014 Liftmaster. Tried for weeks with my M5 and Range Rovers and never worked. Plugged this in an instantly worked.
Didn't have any issues with my 08 M5, but wonder if this is problem with home link in my wifes audi. Thanks for tip!
post #6 of 7 Old 4th September 2018, 02:37 PM
signalMTB
signalMTB's Avatar
certainly...I was beating my head against the wall trying to figure it out. Finally called Liftmaster. Not sure if this is an issue with other brands.
post #7 of 7 Old 6th September 2018, 09:57 PM
texsn95
Yup I had to get a repeater with my Liftmaster, what a pain in the *** to figure it out.
texsn95 is offline
Garage door opener? mhh F10 M5 Discussion 6 17th January 2012 09:25 PM
Garage Door Opener SWP E60 M5 and E61 M5 Touring Discussion 8 16th February 2006 06:09 AM
Garage door opener Fskof E39 M5 and E52 Z8 Discussion 22 11th November 2003 07:59 PM
Garage Door Opener 01M5 E39 M5 and E52 Z8 Discussion 19 9th March 2001 06:40 AM
Garage Door Opener GaryT E39 M5 and E52 Z8 Discussion 17 23rd December 2000 03:01 PM
