SMG Codes. New Battery. Wont Start - BMW M5 Forum and M6 Forums
 2Likes
post #1 of 24 Old 12th March 2018, 06:07 PM Thread Starter
ctk519
2006 E60 M5, with 64K Mi.
Was getting intermittent red and yellow cogs before car finally just won't start. Also its stuck in first gear.
Battery was changed and registered and has been kept on charger. When i unlock the car, voltage drops in half. did the same on previous battery.
Codes I'm getting:
4F40: SMG: Hydraulic unit, Undershooting of pressure range
4F42 : SMG Hyd ctrl unit; activation frequency, pressure build up
4F43: SMG Hyd unit: ON period
5211: SMG: signal, key number, is faulty (CAS)
A46D: CID: CID malfunction due to peripheral
9D12: SINE: internal battery
I'm assuming this is the SMG Pump Motor as I no longer hear the whine when unlock/open door, but could it be something electrical that i'm overlooking? Any idea what the last 2 codes are?
Thanks!
ctk519 is offline
post #2 of 24 Old 13th March 2018, 01:22 AM
Captainl
Captainl's Avatar
Check/change first the smg relay at ecu box for the SMG unit. The correct relay is black for the smg pump. Very cheap from dealer
If the pump dont start you need to buy new pump.
For the last error 9D12 need to remove the rear bumper and open the siren to change batteries
Captainl is offline
post #3 of 24 Old 13th March 2018, 05:12 AM Thread Starter
ctk519
Thanks for your reply. I forgot to mention I changed both black and salmon relays with no luck. When you say change the pump, do you mean the electric motor?
ctk519 is offline
post #4 of 24 Old 13th March 2018, 05:45 AM
sundaycruzers
sundaycruzers is offline
The Following User Says Thank You to sundaycruzers For This Useful Post:
ctk519 (13th March 2018)
post #5 of 24 Old 13th March 2018, 10:46 AM
Captainl
Captainl's Avatar
Captainl is offline
The Following 2 Users Say Thank You to Captainl For This Useful Post:
post #6 of 24 Old 13th March 2018, 05:23 PM Thread Starter
ctk519
Thanks for the replies guys. I have heard that sometimes just the motor (23 01 7 841 032) is what goes bad...and since i can no longer hear the motor, i'm guessing that's my problem. Or will the pump being bad also cause the motor to not start?
ctk519 is offline
post #7 of 24 Old 13th March 2018, 10:46 PM
Captainl
Captainl's Avatar
Yes its common problem!
Carbon from the brushes cause the problem . Probably yours stuck inside and burn the coil.
Dme read 0 pressure from Smg and block the startup.
Captainl is offline
post #8 of 24 Old 14th March 2018, 12:22 AM
lexustbs
lexustbs's Avatar
I have a pump kit from BMW OEM unopened that I will let go for $475 shipped.
Text me 270-57zero-03twofour
Thought I was going to need it as spare parts but I plan on selling the car soon. Can ship out to you tomorrow.
Sent from my Pixel 2 using Tapatalk
2009 BMW M5 STOCK
Looking for a Dinan Exhaust! PM Me.
lexustbs is offline
post #9 of 24 Old 18th March 2018, 02:56 AM Thread Starter
ctk519
Thanks but I’m still trying to figure out what I need. I got ista working and was able to get the car started today after engaging the pump through ista. Once I did this I could hear the pump motor start up and then car fired right up. Which brings me to my next question. Is it just the motor that needs replacing or the actual pump? I’m baffled now as I could hear the pump motor once I engaged it via ista. If the pump itself is bad, would it not allow the motor to prime the system for start?
Edit: are people using pump and motor interchangeably? I'm a noob with this car
ctk519 is offline
post #10 of 24 Old 18th March 2018, 10:14 AM
Hasan Shaikh
Hasan Shaikh's Avatar
Pretty sure they are.
Good luck!
Hasan Shaikh is offline
Tags
smg , transmission fault
E39 M5 wont start after flat battery ecosse79 E39 M5 and E52 Z8 Discussion 10 24th February 2017 12:36 AM
SMG Keeps priming Car wont start whotry E60 M5 and E61 M5 Touring Discussion 9 27th November 2015 03:04 AM
Help! Charged Battery, Car wont Start Needs Code Dcollins E39 M5 and E52 Z8 Discussion 4 15th December 2014 12:52 AM
High battery drain Message then car Wont start. NY06M5 E60 M5 and E61 M5 Touring Discussion 2 3rd April 2011 03:38 AM
Help, my M5 wont start mojo_m5 E39 M5 and E52 Z8 Discussion 14 9th December 2005 02:39 PM
