Pentosin dripping after clutch replacement - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 24 Old 11th March 2018, 05:22 PM Thread Starter
Michael Isaack-Larsen
Hi
I have replaced clutch, DMF and more.
After lifting the gearbox up to horisontal pentosin dripped out of the hole between gearbox and motor.
Everything was 100% dry before installation.
I can only Imagine that it is from the slave cylinder. Therefor i checked the level. It was full / a bit overfilled.
I also put the battery back on and made a few shifts. It did not provoke more spilling.
What do you think?
Thanks in advance guys.
Sendt fra min ONEPLUS A5000 med Tapatalk
Michael Isaack-Larsen is offline
post #2 of 24 Old 11th March 2018, 09:31 PM Thread Starter
So.. maybe its not pentosin after All.
Just pulled the tranny again and IT is comming from the engine side.
I will let it sit until tomorrow and see..
post #3 of 24 Old 12th March 2018, 12:44 AM
lexustbs
lexustbs's Avatar
Is it blue? Coolant? No clue how it could get in there though.
Sent from my Pixel 2 using Tapatalk
2009 BMW M5 STOCK
Looking for a Dinan Exhaust! PM Me.
lexustbs is offline
post #4 of 24 Old 12th March 2018, 06:39 PM
jcolley
jcolley's Avatar
There is a coolant crossover line at the rear of each head that goes to the heater core. Likely either a decayed / frayed rubber hose, bad Oetiker clamp on it, or leaking where the crossover pipe joins the heads.
jcolley is online now
post #5 of 24 Old 12th March 2018, 07:59 PM Thread Starter
This is after 24hours.
The coolant was lying inside the clutchhousing.
The piping over the flywheel seems 100% dry.
post #6 of 24 Old 12th March 2018, 08:02 PM Thread Starter
OK.
I Will have a look. IT is not the one om Thisted picture?
post #7 of 24 Old 12th March 2018, 08:11 PM
lune
Auto correct in Denmark :-) Sorry
IT is not the one om Thisted picture? = It is not the one on this picture?
lune is offline
post #8 of 24 Old 13th March 2018, 01:19 AM
lexustbs
lexustbs's Avatar
That's for sure coolant. Try sticking a paper towel one ply thick above the bell housing and see where drops land.
2009 BMW M5 STOCK
lexustbs is offline
post #9 of 24 Old 13th March 2018, 10:03 AM Thread Starter
post #10 of 24 Old 13th March 2018, 09:54 PM Thread Starter
Just had look again tonight. I can absolutely not find any wet spots anywhere but the place where the drop is hanging..
In the holes on the picture there are 4 torx that I was able to tighten a bit using a hand screwdriwer (torx).
IT does not make sense :-(
Transmission Oil Pentosin MTF-2 (83220309031) discontinued? Pentosin FFL-4? ASW338 E60 M5 and E61 M5 Touring Discussion 12 18th July 2017 01:16 PM
DIY - S62 V-belts replacement and fan clutch replacement. J Irwan E39 M5 and E52 Z8 Discussion 56 8th May 2017 12:17 AM
Clutch/Transmission Issues after Clutch Replacement - Help Needed BCUZICAN540 E39 M5 and E52 Z8 Discussion 11 26th November 2013 10:07 PM
Oil dripping from fan shroud after oil cooler replacement bryanba E60 M5 and E61 M5 Touring Discussion 6 25th July 2013 07:33 PM
Dripping brake caliper BenS E34 M5 Discussion 15 16th September 2010 02:21 PM
