Pentosin dripping after clutch replacement - Page 2 - BMW M5 Forum and M6 Forums
 1Likes
post #11 of 24 Old 13th March 2018, 11:30 PM Thread Starter
Michael Isaack-Larsen
Finally.
Pulled the clutch and DMF.
How is this possible? IT seems to bedste comming out of the little hole next to the screw.
Sendt fra min ONEPLUS A5000 med Tapatalk
Michael Isaack-Larsen is offline
post #12 of 24 Old 14th March 2018, 12:18 AM
lexustbs
lexustbs's Avatar
Interesting. Are you for sure that little hole or the hex head beside it? Hoping that hex head and all you need is a new crush washer or oring. At least you know where it's at now.
Sent from my Pixel 2 using Tapatalk
2009 BMW M5 STOCK
Looking for a Dinan Exhaust! PM Me.
lexustbs is offline
post #13 of 24 Old 14th March 2018, 02:36 AM
jcolley
jcolley's Avatar
Let me look on a block tomorrow, but I think that's the main oil gallery plug, not a coolant plug.
jcolley is offline
post #14 of 24 Old 14th March 2018, 07:36 AM Thread Starter
post #15 of 24 Old 14th March 2018, 07:48 AM Thread Starter
That would be nice. Thanks
post #16 of 24 Old 14th March 2018, 10:53 PM Thread Starter
The 2 small holes are "open". Tried with a qtip to soak up the coolant and for sure it was open a few centimeters in there. Maybe it is in the V?
post #17 of 24 Old 15th March 2018, 02:52 AM
//Martuci
//Martuci's Avatar
I looked over some S85 engine block pics, and as you can see in the attached picture , in the red circle you can spot two small holes on both side of the oil line. It seems to me that they are kind of drain holes. Most likely, coolant would be dripping back somewhere from the thermostat housing or the two connectors to cyl head 1 and cyl head 2, as this would be the place where coolant liquid is present in the V area.
//Martuci is offline
post #18 of 24 Old 15th March 2018, 09:14 AM Thread Starter
post #19 of 24 Old 16th March 2018, 04:53 AM
lexustbs
lexustbs's Avatar
Thermostat leaking up front and running back? I'd pull the plenums and see what's up.
2009 BMW M5 STOCK
lexustbs is offline
post #20 of 24 Old 16th March 2018, 06:41 AM
Garfunkgrin
Garfunkgrin's Avatar
That would be ultra annoying to pull the tranny only to find an unrelated coolant leak on the top side...
Feel for ya!
Garfunkgrin is offline
Transmission Oil Pentosin MTF-2 (83220309031) discontinued? Pentosin FFL-4? ASW338 E60 M5 and E61 M5 Touring Discussion 12 18th July 2017 01:16 PM
DIY - S62 V-belts replacement and fan clutch replacement. J Irwan E39 M5 and E52 Z8 Discussion 56 8th May 2017 12:17 AM
Clutch/Transmission Issues after Clutch Replacement - Help Needed BCUZICAN540 E39 M5 and E52 Z8 Discussion 11 26th November 2013 10:07 PM
Oil dripping from fan shroud after oil cooler replacement bryanba E60 M5 and E61 M5 Touring Discussion 6 25th July 2013 07:33 PM
Dripping brake caliper BenS E34 M5 Discussion 15 16th September 2010 02:21 PM
