High battery drain & SMG issue ! - Page 3 - BMW M5 Forum and M6 Forums
 1Likes
post #21 of 29 Old 21st March 2018, 10:27 AM
Com6
Com6's Avatar
Correct!
This is a quote from JColley on another post concerning priming the smg hydraulic pump:
"Did you prime the pump after reassembly before trying to bleed it? If not, your block is air-bound. There is a check valve internal, on the discharge of the pump. If you haven't purged the air between the pump discharge and the check valve, the pump can't create enough pressure to open the check valve and commence flowing fluid.
There is an aluminum drain plug on the bottom of the hydraulic block underneath the pressure and temp sensors. Unscrew and remove that plug. Activate the pump in DIS/INPA/ISTA/Whatever until fluid issues from the bottom of the block. Turn the pump off, replace the drain plug. Now the pump is primed and you can run the bleeding process."
Hope this helps you.
Com6 is offline
post #22 of 29 Old 21st March 2018, 01:12 PM Thread Starter
Captainl
Captainl's Avatar
Correct Jcoley word's!
Even with this nothing at all......
No pressure!!
Open everything again and check the orings!!
2 of them is wrong.....pffff
I put again the original and put it back....
Still the same
Now I'm trying the clutch slave cylinder ventilation with the screw under the block few turns open!
Probably after some times fluid comes out???
According ista yes... any suggestions??
Captainl is offline
post #23 of 29 Old 21st March 2018, 01:43 PM
Com6
Com6's Avatar
In order to prime the pump you have to remove the bottom plug completely, then activate the pump via ISTA until you get fluid pouring out the plug hole. Then only you re-install the plug. If you only unscrewed it a bit this won't work. I suggest you check the level of the pentosin again after you have primed the pump, if there is not enough in the tank after the system is primed, there is no chance the pressure will build up in the accumulator.
Lack of pressure is:
Lack of fluid
Unoperative/weak pump. How were the collectors on your pump motor?
Deffective accumulator, seems very rare.
Deffective seal, oring or whatever, you checked it.
Deffective solenoid piston, that is internal leak, needs replacement of the solenoid unless you have the facilities to rebuild a cartridge.
Deffective solenoid coil.
Clutch cylinder leak,
Deffective sensor or harness
You name it
As you say, dismanteling every thing for no result is waste of time and money. Plus it is frustrating...
Silly question maybe, what about your pressure sensor? once you have primed the pump, even if the pressure does not build at full working pressure you should read something on ISTA, not zero! When you depressurize the system, ISTA reads 1bar, which is atmospheric pressure, not zero.
Com6 is offline
post #24 of 29 Old 21st March 2018, 02:48 PM
Com6
Com6's Avatar
Com6 is offline
post #25 of 29 Old 21st March 2018, 04:03 PM Thread Starter
Captainl
Captainl's Avatar
Originally Posted by Com6 View Post
Have you seen that thread ? check post #13
https://www.m5board.com/vbulletin/e60...ressure-2.html
Noooooooo.......pfffff I have 1000 bar pressure and didn't notice!!! I hope to solve it ��
Captainl is offline
post #26 of 29 Old 27th March 2018, 09:21 AM
Com6
Com6's Avatar
Com6 is offline
post #27 of 29 Old 29th March 2018, 03:50 PM Thread Starter
Captainl
Captainl's Avatar
Hello!!!
Sorry for the delay of reply but i start working again and my time is limited.
YEEESSS i fix it!!!
My big mistake ..... when i reassembly the electric motor , accidentally rotate the body with the magnets to find the "way" for the bolts.....
When you have a DC motor like this one , when you rotate the body also rotate the polarity!!!!! So the motor turn from the opposite direction eekeek
I figure my mistake when i take out all the unit from the car and put it to my bench and just give 12v to the motor! When i connect it opposite , immediately the pump charge the accumulator !!!!
So i rotate the body and everything work perfect !!
Put everything back to the car start ISTA and pressure is back!!! Bleeding start normal and finish with 64 psi from 27psi that i have before!!!!!!!!
I big smile at my face
Now the pump need only 5 seconds to build the pressure when i open my door! The gears is faster and smoother , without delays .
Electric motor is stronger with total different sound.
My only disappointing is the clutch issue that is still there !! 99% i need PLCD sensor.
Information to all.....
O-Rings dimensions FOR THE SOLENOID ( Viton high temp and oil resistance )
11.5 X 1.5
12.5 X 1.5
13.5 X 1.5
14.5 X 1.5
all the others is easy to find so i dont keep the numbers
Captainl is offline
post #28 of 29 Old 29th March 2018, 04:47 PM
Com6
Com6's Avatar
Great to read you solved the priming problem. Sure it is better if the motor is turning on the right way! It is an interresting feedback though on what could go wrong when reassembling this DC motor.
Thank you very much for the dimensions I assume the diameters are outside diameters.
Com6 is offline
The Following User Says Thank You to Com6 For This Useful Post:
Captainl (30th March 2018)
post #29 of 29 Old 31st March 2018, 10:21 AM Thread Starter
Captainl
Captainl's Avatar
All the job is pretty easy if you have tools , instructions/torque , otherwise you need a lot of hours!!
The diameters is inside always!! The external diameter is determined by the thickness
Captainl is offline
The Following 2 Users Say Thank You to Captainl For This Useful Post:
Com6 (2nd April 2018)
Battery drain issue mick dobbo M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 2 6th September 2016 05:25 PM
Battery Drain issue... pyro225 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 9 6th May 2016 12:42 AM
WEIRD INTERMITTENT ISSUE (Related to crank & battery drain) je39m5 E39 M5 and E52 Z8 Discussion 29 29th April 2016 10:19 PM
Door Handle & High Battery Drain jspalmer E60 M5 and E61 M5 Touring Discussion 4 12th July 2007 07:27 AM
Weak battery headzup! [SMG stuck in gear due to battery drain] Mr. Vroom E60 M5 and E61 M5 Touring Discussion 7 12th May 2007 03:30 AM
