High battery drain & SMG issue ! - Page 2 - BMW M5 Forum and M6 Forums
 1Likes
post #11 of 29 Old 14th March 2018, 10:49 PM Thread Starter
Captainl
Captainl's Avatar
Originally Posted by ruben356 View Post
You could start with an SMG adaptation, 40+MPH shift to neutral, hold both paddle shifters for about 5 seconds, and see if that helps any. On the more affordable end you could start with the PLCD. It might just be bad. Otherwise your clutch could be on its way out.
Thaks but already do it without luck.....
i think PLCD is the problem but i dont like to guesing and removing parts without to be sure.
The clutch normal makes diferent kind of problem such as sliping between gears , at start or during heavy pushing of pedal. Never have this issues.
Someone more experience to SMG can give an opion.
Captainl is offline
post #12 of 29 Old 14th March 2018, 11:26 PM
ruben356
Unless someone with more direct SMG knowledge can chime in, the only to possibly test the PLCD first is with ISTA+. Good luck
ruben356 is offline
post #13 of 29 Old 15th March 2018, 11:09 AM Thread Starter
Captainl
Captainl's Avatar
"Someone more experience to SMG can give an opinion"
Sorry if I'm rude but this is for me! Offcource I don't want to blaim someone!!!!
How can I check it???? I never see it at ISTA
Captainl is offline
post #14 of 29 Old 16th March 2018, 11:21 PM Thread Starter
Captainl
Captainl's Avatar
After a search I think here is the PLCD test
High battery drain & SMG issue !-20180316_171313_1521235669812.jpg High battery drain & SMG issue !-20180316_171522_1521235772104.jpg
BUT....i make also an accumulator test....
And failed!!!!!
Also no errors from Smg
Captainl is offline
post #15 of 29 Old 18th March 2018, 11:58 AM Thread Starter
Captainl
Captainl's Avatar
It's possible the clutch control valve to be faulty and cause this problem? ( changing a set of orings to solenoid I it's easy and cheap ) I don't believe accumulator has problem.....somewhere read JCOLLEY word's that accumulators is difficult to be faulty!
Also the reading at photos is correct??
Captainl is offline
post #16 of 29 Old 20th March 2018, 07:30 PM Thread Starter
Captainl
Captainl's Avatar
I diside to open the hydraulics.....change orings, oil and check if everything is fine! Also open the electric motor....one of the bearing need change ! Clean also the carbon dust and wash it . Replace the clutch valve orings with viton .....and hope for the best....
Captainl is offline
post #17 of 29 Old 20th March 2018, 07:32 PM Thread Starter
Captainl
Captainl's Avatar
Captainl is offline
post #18 of 29 Old 20th March 2018, 09:00 PM
Com6
Com6's Avatar
The quantity of carbon dust is impressive. Good luck.
Do you have the dimensions for the o rings by chance?
Com6 is offline
post #19 of 29 Old 21st March 2018, 12:05 AM Thread Starter
Captainl
Captainl's Avatar
Yes it's true.....i have the numbers but I can post it tomorrow!
The serious problem is that i can't bring pressure back!!!!!! All test fails!!! Check connections start pump manual , everything working but the pressure stays 0!!
Any idea?
Captainl is offline
post #20 of 29 Old 21st March 2018, 01:08 AM Thread Starter
Captainl
Captainl's Avatar
I found the problem...Maybe.
After reassembly everything in place i don't unscrew the plug completely underneath the pressure and temp sensors to prime the pump!!!!!!!!!!!!!
So i haven't purged the air between the pump discharge and the check valve, the pump can't create enough pressure to open the check valve and commence flowing fluid.
Correct???
Captainl is offline
Battery drain issue mick dobbo M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 2 6th September 2016 05:25 PM
Battery Drain issue... pyro225 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 9 6th May 2016 12:42 AM
WEIRD INTERMITTENT ISSUE (Related to crank & battery drain) je39m5 E39 M5 and E52 Z8 Discussion 29 29th April 2016 10:19 PM
Door Handle & High Battery Drain jspalmer E60 M5 and E61 M5 Touring Discussion 4 12th July 2007 07:27 AM
Weak battery headzup! [SMG stuck in gear due to battery drain] Mr. Vroom E60 M5 and E61 M5 Touring Discussion 7 12th May 2007 03:30 AM
