E60 M5 rob bearing or vanos noise?? please help - BMW M5 Forum and M6 Forums
post #1 of 6 Old 8th February 2018, 09:21 PM Thread Starter
deceneu
Hello,
Any ideas if this is a vanos noise or rob bearing?
https://www.youtube.com/embed/r-vC87Ejov4?rel=0
Thank you
deceneu is offline
post #2 of 6 Old 8th February 2018, 09:40 PM
jcolley
jcolley's Avatar
jcolley is offline
The Following 2 Users Say Thank You to jcolley For This Useful Post:
deceneu (8th February 2018)
post #3 of 6 Old 8th February 2018, 09:45 PM Thread Starter
deceneu
is this engine worth fixing? the labor is very cheap where I live.... is it likely that the crank is not serviceable?
deceneu is offline
post #4 of 6 Old 8th February 2018, 09:59 PM
jcolley
jcolley's Avatar
Most likely will require a weld build up and grinding on the crank to fix. Where are you located? A google search will show some places that repair this crank. It's a fairly significant effort though to split the bedplate, remove it, replace it and all the bearings, and reseal it properly. Cheap labor probably is going to be proficient labor with this motor.
jcolley is offline
post #5 of 6 Old 8th February 2018, 10:32 PM
kutila
kutila's Avatar
Cheap labor sometimes not working properly with these cars.
If u are going to rebuild properly u will be just in gaskets and bearings around 3500$ (main bearings, rod bearings, piston rings, bolts, head gaskets)
If u are looking for cheapest way - that is junkyard 6000$ engine, they should warranty it for at least 6 months, try to get it from a big company.
And no, this is not 500$ repair if u decide to go with cheap repair in a garage that never had this car before they will end up changing bearings, and in 60-90 miles (depending how you will drive) u will have same knock or worth scenario hole in the oil pan.
Good luck, i feel your pain, i was in the same boat almost 2 years ago.
LMK if u decide to sell your car
kutila is offline
post #6 of 6 Old 11th February 2018, 05:18 PM
kei03174
This must be hurting me to say.
the sound is universal for any car on Earth,
you spun your bearings.
Definitely not Vanos rattle or Vanos pump
if anybody tell you otherwise, they are trying to sell you into the hell.
Good Luck
kei03174 is offline
Bearing noise? gino19 E39 M5 and E52 Z8 Discussion 1 27th October 2015 05:47 AM
Vanos noise or Timing Chain noise MYM05 E39 M5 and E52 Z8 Discussion 92 26th July 2011 04:27 PM
Still got a bearing noise madm5 E34 M5 Discussion 0 31st May 2006 12:43 PM
Rear Wheel Bearing Noise Bob Uenaka E39 M5 and E52 Z8 Discussion 6 6th March 2005 06:34 AM
wheel bearing noise tonym5 E34 M5 Discussion 4 28th January 2005 08:03 AM
