SMGIII programming - BMW M5 Forum and M6 Forums
post #1 of 5 Old 7th February 2018, 09:07 PM Thread Starter
stephenf121
SMGIII programming
Is it possible to program the SMGIII transmission to downshift to the lowest gear possibly with a single paddle pull, similar to the e90 M3 with DCT? They simply pull and hold the downshift paddle and the car will grab the lowest gear possible, while we have to pull the paddle multiple times. @jcolley this sounds like something you would be knowledgeable about...
stephenf121 is offline
post #2 of 5 Old 7th February 2018, 10:02 PM
jcolley
jcolley's Avatar
Nope. Next time I'm in IDA looking at mss65, I'll grab a screen shot of the code for the SMG shift sequence. Completely different than the DCT.
jcolley is offline
post #3 of 5 Old 8th February 2018, 12:59 AM Thread Starter
stephenf121
post #4 of 5 Old 8th February 2018, 05:55 PM
ruben356
When in Auto mode and flooring the gas, does the trans not do this already? Could this be some programming that tells it to do that, or is it set to downshift to 3rd gear every time it detects a stomp on the throttle? I think it always shifts down to 3rd when i stomp the gas in auto and at a higher gear like 5-7, not sure if it would downshift lower if you are currently in gears 3-5.
ruben356 is offline
post #5 of 5 Old 8th February 2018, 10:45 PM Thread Starter
stephenf121
Yes, in auto mode the car will detect the lowest gear possible when flooring it and grab that gear for you, thats why I don't understand why can't it be programmed to do the same thing in manual mode by holding the downshift paddle and flooring it like the m3 with dct... I assume its more complicated then it sounds but I wish it could be done
Clutch or smgIII Gearbox? laki666 E60 M5 and E61 M5 Touring Discussion 2 18th August 2012 04:08 AM
SMGIII Clutch control? DUR0N E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 4 19th November 2011 07:19 AM
What If there were a retro-fit for the SMGIII on the S-62? TopEnd E39 M5 and E52 Z8 Discussion 13 14th March 2008 06:13 PM
SMGII vs. SMGIII? ///E63M6 E60 M5 and E61 M5 Touring Discussion 2 17th September 2007 05:50 AM
Paddle-less SMGIII M5 Gustav E60 M5 and E61 M5 Touring Discussion 9 22nd May 2004 02:43 AM
