This the right Oil? - BMW M5 Forum and M6 Forums
post #1 of 13 Old 7th February 2018, 01:47 AM Thread Starter
godnf8
godnf8's Avatar
This the right Oil?
I ordered this kit that advertises as Castrol TWS edge professional and got EDGE Supercar
Is this the same stuff/right oil? I wasn't able to attach a picture for some reason, said max allowed size 0kb
Here is a link to comparison photo https://drive.google.com/file/d/1cbh...ew?usp=sharing
godnf8 is offline
post #2 of 13 Old 7th February 2018, 02:47 AM
lexustbs
lexustbs's Avatar
Yes. Close enough. TWS is almost a ghost now. The supercar has the M approval.
Sent from my Pixel 2 using Tapatalk
2009 BMW M5 STOCK
Looking for a Dinan Exhaust! PM Me.
lexustbs is offline
post #3 of 13 Old 7th February 2018, 02:49 AM Thread Starter
godnf8
godnf8's Avatar
Sorry for all the questions, new to board and can't seem to find exactly what i'm looking for through board searches, though google has turned up a few on other forums that have seemed to suggest supercar is castrol's "now" top of the line and replaces all other products including edge tws professional. Do you know if any differences between the two as far as additives and oil thickness or withstanding to heat?
godnf8 is offline
post #4 of 13 Old 7th February 2018, 02:51 AM
TexaZ3
TexaZ3's Avatar
Liqui Moly 10w60 Synthoil Race Tech GT1. That's what I would use.
E36 1999 M3 Coupe Dakar Yellow/Black Vaders
E36 2000 M Coupe Cosmos Black/Black Leather, Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein.
E39 2000 M5 Imola/Black Heritage
E46 2005 M3 Coupe ZCP Carbon Black/Black
E63 2006 M6 Coupe Indianapolis Red/Black/Madeira, Style 343
TexaZ3 is offline
post #5 of 13 Old 7th February 2018, 02:53 AM Thread Starter
godnf8
godnf8's Avatar
What if you had an extended warranty and needed to abide by BMW service bulletins? Edge TWS Professional is on latest copy I have found for the E60 M5. Not Edge Supercar.
godnf8 is offline
post #6 of 13 Old 7th February 2018, 03:06 AM
marioasoler
I use Liqui Moly Race Tech GT1 10w-60.
From my understanding on any warranty and or extended warranty, you should not have any issues as long as the "oil" you are using its compatible with the engine of use.
marioasoler is offline
post #7 of 13 Old 7th February 2018, 01:24 PM
Jahangeer
Jahangeer's Avatar
Liquid Moly is probably a good oil, but shouldn't you go for the higher API i.e. Liq Moly is API SL, however Shell Helix Ultra 10w60and Castrol 10w60 are both API SM, i.e. newer.
API
This is the more basic as it is split (for passenger cars) into two catagories. S = Petrol and C = Diesel, most oils carry both petrol (S) and diesel (C) specifications.
The following table shows how up to date the specifications the oil are:
PETROL
SG - Introduced 1989 - has much more active dispersant to combat black sludge.
SH - Introduced 1993 - has same engine tests as SG, but includes phosphorus limit 0.12%, together with control of foam, volatility and shear stability.
SJ - Introduced 1996 - has the same engine tests as SG/SH, but phosphorus limit 0.10% together with variation on volatility limits
SL - Introduced 2001 - all new engine tests reflective of modern engine designs meeting current emissions standards
SM - Introduced November 2004 - improved oxidation resistance, deposit protection and wear protection, also better low temperature performance over the life of the oil compared to previous categories.
Shell:-
ACEA A3
ACEA B3
ACEA B4
API CF
API SN
Liq Molly:-
ACEA A3
ACEA B4
API CF
API SL
Regards
J (formerly SchrickM5)
Current ride:-
2014 M5 Competition
Alpine White III
Jahangeer is offline
post #8 of 13 Old 7th February 2018, 05:44 PM
JohnAnthony
JohnAnthony's Avatar
Depends on what was improved/changed for the subsequent API class. You really only need the API class that was available in 2005/2006 when the S85 was released. Right now they're close enough that it doesn't make much of a difference. Eventually e.g. API SS, ST, STU...SZ will not be compatible.
As for the correct Castrol TWS; I think Castrol consolidated the two (2) different 10W60 that once existed. When the S62 was released Castrol specifically sold Castrol TWS (Ten W Sixty) with M-approval this was an Ester synthetic. There was another Castrol 10W60 that was PAO based, and did not carry M-Approval. I can only recall one time here in the U.S. when the PAO oil was available, the name was: Castrol 10W60 Edge Sport, and it did not include the TWS brand, nor any BMW M-Approval or similar recommendation. Lastly the bottle design doesn't matter, they change the design based on regional and global marketing even when there is only a minor change in regulation or formulation.
for reference some Castrol TWS bottles throughout the years
ID:	850097   Click image for larger version
JohnAnthony is offline
post #9 of 13 Old 7th February 2018, 07:34 PM Thread Starter
godnf8
godnf8's Avatar
The current Edge Supercar I received seems to have the M Approval so I'm assuming I'm good to go with what I go
2008 BMW M5 E60 Current DD
godnf8 is offline
post #10 of 13 Old 7th February 2018, 08:09 PM
JohnAnthony
Yes, M-approved or Recommended for BMW M-Models is good to go. The other oil that does not include BMW Approval/M-Approval is simply a different formulation. It's not a bad formulation, just not as good as the original TWS/BMW version.
What do you do about the oil in the oil cooler when you do an oil change? SFTitanium5 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 1 29th October 2013 04:16 PM
oil level still showing low after oil change and 10 qts of oil supark E60 M5 and E61 M5 Touring Discussion 16 26th March 2013 06:02 AM
Oil in oil filter housing not draining during oil change:( CarbonHan E39 M5 and E52 Z8 Discussion 8 13th January 2012 05:02 PM
Took off my front skid plate to install a new oil pan (oil consumption or oil leak...?!) blks4 E39 M5 and E52 Z8 Discussion 7 19th August 2011 10:34 AM
Oil Burning/ Oil wieght/ Oil Brand m1008cucv E34 M5 Discussion 26 21st December 2005 12:17 PM
