indicator type for setting backlash - BMW M5 Forum and M6 Forums
post #1 of 3 Old 2nd February 2018, 08:49 AM Thread Starter
dr_dirtg
dr_dirtg's Avatar
Hey guys Im going to be doing my rod bearings in 2 weeks and would like to know if a vertical test indicator will work to check vanos pump backlash?
or do i have to use a horizontal test indicator?
dr_dirtg is offline
post #2 of 3 Old 2nd February 2018, 08:36 PM
flacoramos
If what you're thinking is to use a classic dial indicator to measure the tangential movement of the gear then I can tell you that I tried and failed. The tips are just not small enough to get good contact and then there is the helical angle causing the tip to slip, etc.
Ended up buying a test indicator on amazon. Try your local craigslist too, I've found mitutoyos for cheap.
flacoramos is offline
post #3 of 3 Old 3rd February 2018, 07:02 PM Thread Starter
dr_dirtg
dr_dirtg's Avatar
ok thank you this is what i needed.
I ended up buying the exact same one used in the G.A.S DIY for the rod bearing job. It's a Mitutoyo 513-402 in case anyone is wondering.
dr_dirtg is offline
How to attach mitutoyo backlash gauge gmak E60 M5 and E61 M5 Touring Discussion 4 2nd June 2016 06:01 PM
Can some one watch this vanos pump backlash video and tell me how it looks jokergerm E60 M5 and E61 M5 Touring Discussion 1 31st December 2014 05:05 AM
Vanos pump backlash and block/bedplate sealing Raptor6702 E60 M5 and E61 M5 Touring Discussion 37 17th July 2014 07:48 AM
M3 For Sale: FS: AC Schnitzer Type III (Type 3) e36/e46 18" Wheels/Tires - REAL, Not Replica brad @ evosport Parts / Other For Sale or Wanted 0 29th October 2009 08:44 PM
pinion preload and backlash rom4ik E39 M5 and E52 Z8 Discussion 1 18th September 2007 09:25 PM
