Possible misfire under acceleration and idle, no CEL - BMW M5 Forum and M6 Forums
post #1 of 10 Old 20th January 2018, 05:42 AM Thread Starter
hashtagdriven
Drove the M5 first time in a week and 10 minutes into the drive the car began to jerk anytime I started to accelerate. Also noticed a rough idle during a cold start few minutes ago. There is no check engine light and Carly scan came back with no fault codes. Jerkiness doesnít depend on the speed.
Any ideas? Car has 55k miles, so spark plugs are dead? Bad coil pack? Throttle actuators? Car had 1/4 tank of gas...canít imagine gas going bad.
Help is greatly appreciated!
Oh and if it is a coil pack, go with BMW units or do people use something else?
Follow me on Instagram @hashtagdriven
hashtagdriven is offline
post #2 of 10 Old 20th January 2018, 07:12 AM
JVP
JVP's Avatar
I had this issue last year. No CEL and it was indeed misfiring. CEL would come on if I red lined it. Coils and plugs were checked but they were not the culprit. It turned out that something had broken off the throttle actuator forcing #9 to not open. Was an easy fix for my mech.
JVP is offline
post #3 of 10 Old 20th January 2018, 08:58 AM Thread Starter
hashtagdriven
Do you recall if any parts had to be replaced and if any codes were present?
Thanks!
post #4 of 10 Old 21st January 2018, 01:54 AM Thread Starter
hashtagdriven
Ladies and gentleman, fault codes have arrived. Perhaps the module that delivers these fault codes is also malfunctioning...
Is it safe to assume that itís my throttle valve actuator going out and needing to be replaced? I saw posts about 2B21 fault code being the bank 1 actuator, so 2B22 would mean itís bank 2? How do I tell which one is bank 1 and bank 2?
Thanks!
post #5 of 10 Old 21st January 2018, 02:06 AM Thread Starter
hashtagdriven
Above pictures are of the freeze frames I got out of Carly.
post #6 of 10 Old 21st January 2018, 05:51 AM
JVP
JVP's Avatar
Thanks!
There were a couple of codes after I caused the CEL to come on by red lining the car but unfortunately, I cannot remember nor did I keep a record of them My mechanic replaced a part on the throttle bodies if I remember correctly and it was very inexpensive - told me to buy him a drink Sorry I can't be of more help
JVP is offline
post #7 of 10 Old 21st January 2018, 05:44 PM
richku1
richku1's Avatar
Isnt the 2b57 the MAF sensors. Before i cleaned mine they were setting off other codes. Worth a shot to clean them and run the car for a few days.
Sent from my SM-G860P using Tapatalk
V10
richku1 is offline
post #8 of 10 Old 28th January 2018, 03:01 AM Thread Starter
hashtagdriven
Just to close the loop: all errors were caused by a faulty Throttle Actuator. I replaced both and took this as an opportunity to replace the spark plugs. M5 is alive again!
post #9 of 10 Old 28th January 2018, 01:37 PM
JVP
JVP's Avatar
Glad to see you sorted the issue out! Happy ///M'ing
JVP is offline
post #10 of 10 Old 28th January 2018, 07:40 PM Thread Starter
hashtagdriven
Thank you! Makes me wonder if not driving the car for long time periods causes things to go break more often...moisture/condensation buildup, grease/oil hardening, etc.
Strange Stumble, shake, and misfire under acceleration MN_M5 E39 M5 and E52 Z8 Discussion 3 3rd February 2015 05:50 AM
DIY: rough idle, intermittent misfire cbarry E39 M5 and E52 Z8 Discussion 7 10th November 2012 01:11 AM
misfire/stutter at idle ktmking E34 M5 Discussion 9 13th December 2007 07:10 PM
Poor Idle and Misfire derheilige82 E39 M5 and E52 Z8 Discussion 2 27th September 2007 09:19 PM
Misfire under full acceleration and SES warning? jds E39 M5 and E52 Z8 Discussion 48 11th April 2007 01:20 PM
