27b6 camshaft control inlet bank 2 output stage fault code - BMW M5 Forum and M6 Forums
post #1 of 5 Old 15th January 2018, 02:14 PM Thread Starter
Matty.13
Hi guys
I hope one of you might be able to help . My car keeps throwing up this fault code .
The car runs fine and does not throw engine management light. I replaced one of the sensors on this bank with one I had knocking about .
Am I right in thinking there are 2 camshaft sensors per bank?
Also my car in a uk car so bank 2 is the passenger side ?
When the weather gets better I plan on swapping one sides sensors to the other and see if I still get the same fault , in the mean time is this anything to worry about ?
Any advice is greatly appreciated
Matty.13 is offline
post #2 of 5 Old 24th January 2018, 06:53 PM
nizoo_k
i have the same code "27B6" on my 2007 M6. the car drives just fine, altough the CEL is on, waiting on a friend of mine to get the solenoids test via INPA software....
does your car have a rattling noise coming from your vanos area?
nizoo_k is offline
post #3 of 5 Old 24th January 2018, 08:09 PM Thread Starter
Matty.13
No it does not rattle at all . It’s quite strange as the code has not appeared the last time couple of times I have driven the car. Please post if you get any answers . I will be taking my car to a diagnostic expect next month just as a precaution to make sure nothing is wrong .
Matty.13 is offline
post #4 of 5 Old 27th January 2018, 03:05 AM
jcolley
jcolley's Avatar
That would almost seem to me to indicate a problem in either the wiring going to the solenoid or the h-bridge that's driving the solenoid inside the DME.
jcolley is offline
The Following User Says Thank You to jcolley For This Useful Post:
Matty.13 (27th January 2018)
post #5 of 5 Old 27th January 2018, 01:07 PM Thread Starter
Matty.13
Matty.13 is offline
SMG Fault Code 4F21 Transmission Control internal fault (estate) GBNETWORK E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 13 18th June 2018 08:30 PM
DIY: My Experience and Input in Replacing the Inlet Bank 1 (U.S. Passenger Side) CPS Camshaft Position Sensor blks4 E39 M5 and E52 Z8 Discussion 7 14th October 2011 10:09 AM
07/D4 - Signal, camshaft sensor, inlet, bank 1 blks4 E39 M5 and E52 Z8 Discussion 6 8th August 2011 01:16 AM
27BE vanos control bank 2 fault?? jamiepeers E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 6th August 2010 01:30 PM
Code b9 "Exhaust Camshaft 1Vanos Position Control murph550 E39 M5 and E52 Z8 Discussion 3 28th January 2009 03:02 PM
