Aftermarket VANOS Solenoid - Page 5 - BMW M5 Forum and M6 Forums
 159Likes
post #41 of 679 Old 16th December 2017, 06:19 PM
DRMCEO
DRMCEO is offline
post #42 of 679 Old 16th December 2017, 10:47 PM Thread Starter
Sophie
Originally Posted by jcolley View Post
If you find this is consistently the case, you may be able to feed that back to the manufacturer. This means the zero zetpoint for the spool (meaning spool in the middle blocking the flow) requires more current than the OEM.
This can be the result of two things:
1. the easy one, the counter spring in the tip of the solenoid is too strong and requires excessive current to move against.
2. The coil impedance and number of windings are different than the original. This should also be an easy fix with a few more turns on the coil.
In all though, as long as the max current value doesn't exceed what the DME is programmed to allow for max, you shouldn't have a problem. This isn't part of the calibration area, but part of the program area. I have the VANOS area identified in the assembly, I'll see if I can find the max current value that's hard coded in.
You are so good, Jim, as always. Your #2 option is exactly what my manufacturer replied to me when I sent the test results back to them a few months ago. I was told the issue will be taken care of during batch production.
Sophie is offline
post #43 of 679 Old 16th December 2017, 10:49 PM Thread Starter
Sophie
Originally Posted by J.R ///M5 View Post
I hope you can ship these to europe also!
Of course. That is a must.
Sophie is offline
post #44 of 679 Old 17th December 2017, 05:51 AM
seif_ossama
seif_ossama's Avatar
seif_ossama is offline
post #45 of 679 Old 17th December 2017, 06:14 PM
jonbly
jonbly is offline
post #46 of 679 Old 17th December 2017, 11:21 PM
Jollejo
Jollejo's Avatar
Jollejo is offline
post #47 of 679 Old 18th December 2017, 04:01 AM
ernied
ernied is offline
post #48 of 679 Old 18th December 2017, 04:02 AM
alexbigojin
alexbigojin's Avatar
alexbigojin is offline
post #49 of 679 Old 18th December 2017, 02:37 PM
Jahangeer
Jahangeer's Avatar
I am in.... with both feet.
Regards
J (formerly SchrickM5)
Current ride:-
2014 M5 Competition
Alpine White III
Jahangeer is offline
post #50 of 679 Old 18th December 2017, 03:26 PM
djvirus786
I am interested.. Please let me know as soon as possible when you get them. I need them urgently.. Thanks.
djvirus786 is offline
Vanos Solenoid Repair - Thank You Dr.Vanos PaulRuffo E39 M5 and E52 Z8 Discussion 5 16th December 2015 02:59 PM
Vanos solenoid seals Dr. Vanos vs OEM replacement? blackwagon E39 M5 and E52 Z8 Discussion 18 24th January 2011 07:31 PM
throwing vanos solenoid codes on new solenoid pack Msentinel E39 M5 and E52 Z8 Discussion 0 16th June 2010 04:14 AM
Vanos Solenoid - anyone use Dr. Vanos to repair? reds2 E39 M5 and E52 Z8 Discussion 3 2nd March 2010 04:01 AM
Vanos Solenoid vs Complete Vanos Replacement SoCaLE39 E39 M5 and E52 Z8 Discussion 5 4th June 2008 09:42 PM
