2006 M5 Misfire Cylinder 3 (HELP) - Page 5 - BMW M5 Forum and M6 Forums
post #41 of 52 Old 15th December 2017, 03:36 AM
Ferris
Sorry we weren't able to figure it out.... If you can post an update I'd love to know what it was and it could help someone else in the future
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #42 of 52 Old 16th December 2017, 07:06 PM Thread Starter
gvardy
gvardy's Avatar
Definitely, Its been a week and no updates yet...
gvardy is offline
post #43 of 52 Old 7th January 2018, 04:30 AM Thread Starter
gvardy
gvardy's Avatar
Still No updates , Im hoping to hear some type of news this week...... 3 weeks in the shop and no update...
gvardy is offline
post #44 of 52 Old 8th January 2018, 02:28 PM
dr_dirtg
dr_dirtg's Avatar
hi just a question did you check the exhaust valves? perhaps the springs are broken on exh. side?
dr_dirtg is offline
post #45 of 52 Old 8th January 2018, 04:54 PM
nebrou
nebrou's Avatar
spring valve is your problem if you sourced out spark plugs, coil and injectors.
Common problem..
nebrou is offline
post #46 of 52 Old 12th January 2018, 12:37 AM
nebrou
nebrou's Avatar
nebrou is offline
post #47 of 52 Old 16th March 2018, 02:43 AM Thread Starter
gvardy
gvardy's Avatar
Finally no misfire engine running smooth, issue with the coil plug on cylinder 3 also throttle #3 needed to be adjusted, seems like it was moved and not adjusted corrected.
Now Im trying to locate the plug for my ambient temp sensor, its the only code I have left..
gvardy is offline
post #48 of 52 Old 16th March 2018, 04:27 PM
BobbyT
BobbyT's Avatar
Since you mentioned swapping out coils, plugs, injectors, etc., did you swap in a bad coil on #3?
Or was it just the throttle adjustment out of spec the whole time?
BobbyT is online now
post #49 of 52 Old 16th March 2018, 11:26 PM Thread Starter
gvardy
gvardy's Avatar
gvardy is offline
post #50 of 52 Old 15th June 2018, 05:20 PM
tripz
tripz's Avatar
what connector are you referring to? Did you also replace just 1 throttle position sensor?
thanks
tripz is offline
Still having misfire on cylinder #5 andrei_g17 E60 M5 and E61 M5 Touring Discussion 3 7th July 2016 05:53 AM
Cylinder 3 misfire fitabe E60 M5 and E61 M5 Touring Discussion 6 1st October 2015 02:23 AM
First, cylinder 1 misfire; now misfire moved to cylinder 8 misfire huh?! E60 M5 and E61 M5 Touring Discussion 8 10th March 2015 05:31 AM
cylinder 7 misfire scottm E39 M5 and E52 Z8 Discussion 11 25th July 2011 07:11 PM
Whats the likely cause of "199 Cylinder #4 misfire + cylinder cutoff"? aaronmiles E39 M5 and E52 Z8 Discussion 7 24th August 2007 08:18 PM
