2006 M5 Misfire Cylinder 3 (HELP) - Page 2 - BMW M5 Forum and M6 Forums
post #11 of 52 Old 5th December 2017, 04:46 PM
seif_ossama
seif_ossama's Avatar
Since you got the software why donít you start by pulling the codes first then do the vanos bleed
Sent from my iPhone using Tapatalk Pro
seif_ossama is offline
The Following User Says Thank You to seif_ossama For This Useful Post:
gvardy (6th December 2017)
post #12 of 52 Old 5th December 2017, 05:26 PM
Ferris
Just re read it your post... Sorry for not replying earlier. have you pulled the adaption values yet? If so post them
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
The Following User Says Thank You to Ferris For This Useful Post:
post #13 of 52 Old 6th December 2017, 02:51 AM Thread Starter
gvardy
gvardy's Avatar
Sorry I thought I had posted the fault code.. 2B44 Combustion Misfire With Emission Deterioration Cylinder 3. I was not waiting for the software for this I have a scanner that provides the fault code.
gvardy is offline
post #14 of 52 Old 6th December 2017, 02:52 AM
seif_ossama
I would use the software because it is BMW focused instead of the scanners, they are usually generic that donít show all the codes. Just saying may be you should just check
post #15 of 52 Old 6th December 2017, 02:59 AM Thread Starter
gvardy
gvardy's Avatar
I did, I will post them tomorrow, I will have to pull them again..
I did see a difference in the idle air actuator car off 20%, car off full throttle 99.5 bank 1, 99.9 bank 2, now when idle bank 1 will be in single digits or low teens while bank 2 stays in the double digit 15-20% higher, then I rev the car a little at a steady rev and it was the same on both banks, so I only show a difference at idle.
No reading from the secondary air valve..
gvardy is offline
post #16 of 52 Old 6th December 2017, 03:03 AM Thread Starter
gvardy
gvardy's Avatar
also I did another smoke test, same inlet and blocked the bank 2 plenum, I uncovered the oil fill cap to make sure it was traveling, I got smoke from the oil fill and travelled to the bank 2 plenum so i covered everything and did not see any signs of leak...
gvardy is offline
post #17 of 52 Old 6th December 2017, 03:05 AM Thread Starter
gvardy
gvardy's Avatar
I did, same code misfire cylinder 3, had other codes as well but nothing that can lead to a misfire.
gvardy is offline
post #18 of 52 Old 6th December 2017, 03:06 AM
Ferris
My thought was you said you replaced bank 1 O2, It's worth clearing the adaptions and letting it readapt, I'd be interested to see the fuel trims.
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #19 of 52 Old 6th December 2017, 03:11 AM Thread Starter
gvardy
gvardy's Avatar
Will Do, the reason I replaced the o2 besides having a fault I switched them first from bank 1 to bank 2 and the fault moved to bank 2, so really bank 2 has the new o2 sensor but no more o2 faults.
I will delete and read again and post the readings tomorrow.
gvardy is offline
post #20 of 52 Old 6th December 2017, 03:17 AM
Ferris
One last thought, if you can pull the plug let's see.
What are the order of events, i'm sorry if you covered them already. I know you said it happens at idle but is hot/cold ect does it happen immediately, Have you done any other work when it started? how did it start, blah blah.
Sorry for all the questions but I like to know the whole picture.
would't happen to have a boroscope do you?
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
The Following 2 Users Say Thank You to Ferris For This Useful Post:
Still having misfire on cylinder #5 andrei_g17 E60 M5 and E61 M5 Touring Discussion 3 7th July 2016 05:53 AM
Cylinder 3 misfire fitabe E60 M5 and E61 M5 Touring Discussion 6 1st October 2015 02:23 AM
First, cylinder 1 misfire; now misfire moved to cylinder 8 misfire huh?! E60 M5 and E61 M5 Touring Discussion 8 10th March 2015 05:31 AM
cylinder 7 misfire scottm E39 M5 and E52 Z8 Discussion 11 25th July 2011 07:11 PM
Whats the likely cause of "199 Cylinder #4 misfire + cylinder cutoff"? aaronmiles E39 M5 and E52 Z8 Discussion 7 24th August 2007 08:18 PM
