08+ bearings... - BMW M5 Forum and M6 Forums
post #1 of 3 Old 20th August 2017, 08:19 AM Thread Starter
pyro225
pyro225's Avatar
08+ bearings...
I know this subject has been done to death... then done again and again... but I was wondering if anyone with the 702/703 bearings in their engines (revision 3) has either A) had a failure B) changed the bearing and had heavy wear?
Cheers
pyro225 is offline
post #2 of 3 Old 20th August 2017, 02:51 PM
Bucky
From what I have read and heard, the bearing updates ares still just as bad as the previous. It is the crank that is the problem if using non BE bearings.
Bucky is offline
post #3 of 3 Old 20th August 2017, 02:54 PM
gmak
There is a post or two about differences in the 2nd and 3rd generation S85 engines include the oil squirters etc that apparently improve the odds against rod bearing wear. I can't remember which thread it is, but I saw this within the last 2 - 3 days (so since Friday Aug 18, 2017)
Found it:
https://www.m5board.com/vbulletin/e63...ml#post7222361
My M5 Thread: Tire tracks on my soul
Starring: The Perfect B.itch [TM]
gmak is offline
For Sale Rod Bearings banel Parts / Other For Sale or Wanted 1 20th April 2016 04:54 AM
Bimmerzone.com: BE Bearings - Improved Connecting Rod Bearings Set for BMW E60 M5 S85 Engine Bimmerzone.com M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 0 11th November 2015 04:19 PM
Rod Bearings, Which ones should I use? Braheem24 E60 M5 and E61 M5 Touring Discussion 34 24th July 2014 10:39 PM
Rod bearings are in!! 1STOUTM E39 M5 and E52 Z8 Discussion 1 6th July 2013 08:48 PM
S62 engines - big end bearings/rod bearings sam1977 E39 M5 and E52 Z8 Discussion 2 27th October 2011 01:40 AM
