Drreaded 3 lights error tried 2 dsc pulse sensor - BMW M5 Forum and M6 Forums
post #1 of 4 Old 18th August 2017, 11:25 AM Thread Starter
azzy3915
Hi my m5 has the 3 lights on dashboard abs brake and traction I put it on my diagnostic got the fault for front left speed sensor bought a sensor ate branded it didn't work so bought another one direct from bmw this didn't work either way cleared the faults just come straight back on with same faults
Now I have reason to believe after searching the forum it's my wheel bearing how can I be 100% before purchasing a bearing
Also anything else it could be.
Regards
Sent from my SM-G925F using Tapatalk
azzy3915 is offline
post #2 of 4 Old 18th August 2017, 06:31 PM
gmak
You need to look in with a borescope / endoscope and turn the wheel slowly to see if there is any issue with the teeth. Maybe it just needs a good cleaning to define the teeth better.
My M5 Thread: Tire tracks on my soul
Starring: The Perfect B.itch [TM]
gmak is offline
post #3 of 4 Old 18th August 2017, 06:47 PM
xrviz
xrviz's Avatar
Could be crud buildup on the bearing pulse ring but it could also be trouble with the DSC or TPMS modules. Apparently faulty TPMS modules often report as LF speed sensor fault.
Do you have INPA or ISTA/D? If so you can do some real time reads of speed sensors to see which module is faulty. Also you can read sensor outputs at the DSC module connector plug by spinning the wheels. This will test sensors and wheel bearings.
Everything you could possibly want to know is in this thread and summarized in post #48:
2002 E39 ASC BRAKE ABS lights on => Diagnostic Procedure & Parts Location - Bimmerfest - BMW Forums
xrviz is offline
post #4 of 4 Old 20th August 2017, 04:16 AM Thread Starter
azzy3915
That's weird I have also have tyre monitor error on the car iswell as a dynamic damper error
azzy3915 is offline
No speedo, ABS, Break, DSC lights ON - Wheel sensor?? CWY_M5 E39 M5 and E52 Z8 Discussion 8 24th May 2014 05:36 PM
Error codes; car in limp mode, DSC error 27A9 5E1A etc. help please? johnwojo E60 M5 and E61 M5 Touring Discussion 16 4th October 2013 02:10 PM
Error codes; car in limp mode, DSC error 27A9 5E1A etc. help please? johnwojo E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 16 14th August 2013 01:45 AM
DSC problems : "104 Steering angle sensor" error V8Freak E39 M5 and E52 Z8 Discussion 1 10th August 2008 08:47 PM
Pulse sensor replacement nexus1972 E34 M5 Discussion 2 15th December 2005 09:41 PM
