Car shaking really rough - Page 4 - BMW M5 Forum and M6 Forums
post #31 of 38 Old 24th August 2017, 03:27 PM Thread Starter
whotry
No I just swapped them like you said earlier. Unless they are all shot? No, I didn't have to move the plenums fortunately. I will switch the coils as soon as the car cools down a bit.
whotry is offline
post #32 of 38 Old 24th August 2017, 03:30 PM
gmak
Your fault code indicated that they are all shot. If it was faults on just one bank - then swapping 2 from one bank with the 2 on the other bank would be the way to go. I thought that you were getting 4 new ones...
My M5 Thread: Tire tracks on my soul
Starring: The Perfect B.itch [TM]
gmak is offline
post #33 of 38 Old 24th August 2017, 03:31 PM Thread Starter
whotry
Yea I misunderstood, I'll go to bmw today and grab 4 new ones. Should I still switch the coil packs or just wait.
whotry is offline
post #34 of 38 Old 24th August 2017, 03:32 PM Thread Starter
whotry
whotry is offline
post #35 of 38 Old 24th August 2017, 03:33 PM Thread Starter
whotry
whotry is offline
post #36 of 38 Old 24th August 2017, 03:38 PM
gmak
Try switching the coil packs - it will give more information. Also after the switch, clear the fault codes and get a fresh batch and post them. I've done a bunch of stuff on my M5, but I've been lucky with some stuff and I'm just going by the process we use to figure out a misfire on the E39s. The CPS replace is because of the "All 4 failed" in your error codes - but it could just as easily mean that there is something else wrong that is causing the CPS "all 4" fault.
Are they supposed to be that oily - @rt7085
gmak is offline
post #37 of 38 Old 24th August 2017, 03:40 PM Thread Starter
whotry
I was wondering the same thing. If it's supposed to be that oily. I will swap out the coils first just to see if the fault codes move. I clear the codes everytime. Just so I can get the fresh batch of codes that pop up. Fingers crossed
whotry is offline
post #38 of 38 Old 25th August 2017, 12:59 AM
rt7085
rt7085's Avatar
It is supposed to be that oily as it protrudes into the heads where oil runs freely. No big deal. Hence the gasket ring.
The fact that they ALL failed is suspect. That does not happen. Harness issue? Power issue? Anyway, get your new ones and see what happens. Cheap enough compared to some other items on the car.
Besides if the cam sensors all failed the engine could not run properly. It might be a shitty fault scanner translation issue too. It would affect all banks not just bank 1, eg cyl 1 and 4.
rt7085 is offline
Car Shaking on start-up for first minute BADBOY'S M5 E60 M5 and E61 M5 Touring Discussion 4 10th April 2014 07:33 PM
Car is shaking at higher speeds Pepsmeister E34 M5 Discussion 10 9th January 2012 11:36 AM
car shaking M5 Strike E39 M5 and E52 Z8 Discussion 22 8th April 2009 11:25 PM
Why is my car shaking? M5inAtlanta E39 M5 and E52 Z8 Discussion 2 23rd September 2007 10:27 AM
car shaking at startup and after, how come? Poyan E39 M5 and E52 Z8 Discussion 9 1st February 2007 01:01 PM
