Need help coding new CCC - Page 2 - BMW M5 Forum and M6 Forums
post #11 of 19 Old 23rd June 2017, 08:58 PM Thread Starter
BobbyT
BobbyT's Avatar
Originally Posted by terraphantm View Post
Do you have a multimeter? Can you check to see if you're getting power at the bluetooth harness? Also maybe check the fuses.
I can do that. What wires should I try?
BobbyT is offline
post #12 of 19 Old 23rd June 2017, 09:00 PM
terraphantm
terraphantm is offline
post #13 of 19 Old 26th June 2017, 02:52 AM Thread Starter
BobbyT
BobbyT's Avatar
So that harness that I posted earlier did not look like mine. I didn't have a red / green stripe. Instead I had two red / blue stripe. I tried to get a voltage off of both, and couldn't read anything.
BobbyT is offline
post #14 of 19 Old 26th June 2017, 02:58 AM
terraphantm
Is it red, blue, and yellow by any chance? If so, that should also be +12v. If there's no power, sounds like it could be a fuse issue. If I'm reading the diagrams correctly, that would be fuse 37 or fuse 80.
post #15 of 19 Old 26th June 2017, 03:52 AM Thread Starter
BobbyT
BobbyT's Avatar
Here's the harness I have.
I also looked at the F80 fuse. It looks good.
Edit: I think you just uncovered a big one... I don't have an F37 fuse. As in, there's no fuse in that block. It's late, so I'm going to put a fuse in tomorrow, and check again.
BobbyT is offline
post #16 of 19 Old 26th June 2017, 04:45 AM Thread Starter
BobbyT
BobbyT's Avatar
Unbelievable. That was it - I put a fuse in F37, plugged the module in, and it came alive. No idea how that happened.
Only thing now, is that my Galaxy S7 Edge won't pair. It says successful pairing, but then hangs, and doesn't actually pair to my phone. Does something need to be updated in the bluetooth software maybe?
BobbyT is offline
post #17 of 19 Old 2nd September 2017, 03:29 PM Thread Starter
BobbyT
BobbyT's Avatar
Thanks for all the help on troubleshooting. I have everything on now... I ended up putting in a new BT module, even though I'm pretty sure the old one is still good. Galaxy S7 Edge pairs and all is well.
I must have cleared about 100 random errors and IM's in INPA. Coded all the good stuff in, so car is better than ever.
However, what won't work now is voice commands. No chime or anything if I hit the voice button. Not sure where I went wrong there.
BobbyT is offline
post #18 of 19 Old 2nd September 2017, 05:49 PM
terraphantm
Probably lost when you changed the VIN on the CCC. Probably have to load the FSC for your car, though I'm not 100% sure how to do that on a CCC. This archive has all of the FSCs for E60s built until March 2007, so you shouldn't have to order anything from a dealer: https://ulozto.cz/!uB1AsWrZ/fsc-up-to-2007-03-rar
post #19 of 19 Old 3rd September 2017, 04:47 PM
CHARIOT
Terra is correct.
An emulator will probably be much less of a headache than trying to go the legit route with FSCs though.
Even if you re-load the FSC it will disable again as long as your gateway VIN and radio vin do not match. The only way around this is to make them match...once they match, just use the fsc for the matching VIN you chose.
DIY: E60 M5 SMG to 6MT Conversion:https://www.m5board.com/vbulletin/e6...-manual-2.html
CHARIOT is offline
E60 For Sale: I have CCC and CCC Screen from 2008 M5 for sale 335xi Parts / Other For Sale or Wanted 3 30th December 2015 05:11 PM
CCC navigation jcolley Parts / Other For Sale or Wanted 3 13th September 2015 03:59 PM
Ccc not working Lloydv10 E60 M5 and E61 M5 Touring Discussion 1 11th October 2014 01:05 AM
Would my ccc professional be able to replace a ccc business? pyro225 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 18th March 2012 02:21 PM
CCC Access rawone E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 21st June 2008 06:20 AM
