Rear passenger side seatbelt is wet...help! - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By B767capt
post #1 of 3 Old 6th March 2017, 09:35 AM Thread Starter
Hayward135
Hayward135's Avatar
Hi, I'm hoping someone can help. I have a 2008 M5 and recently I noticed my rear passenger side seatbelt is wet (when you pull it out.) When I check the inside of the car everything is dry. I even pulled the trunk liner on both sides and all looks dry. The times it has occurred my car was on the driveway facing the garage door. The drive way is on a slope which means water would roll down towards the back of the car. I am baffled by this one issue, so any help would be appreciated. Thanks!
Hayward135 is offline
post #2 of 3 Old 6th March 2017, 01:18 PM
B767capt
B767capt's Avatar
I would open your moon roof and pour water in the tracks at each corner and verify the water is draining out onto the ground behind each tire. You may have a drain tube problem. This is an expensive and serious problem in the E61.
B767capt is offline
post #3 of 3 Old 7th March 2017, 05:19 AM Thread Starter
Hayward135
Hayward135's Avatar
Thanks, I will give that a try...Hopefully it's that and I can clear/correct myself...
Seatbelt rub noise - passenger side F10-M5 F10 M5 Discussion 5 24th February 2016 04:57 PM
Driverside rear sits lower than passenger side JT///M5 E60 M5 and E61 M5 Touring Discussion 0 26th March 2010 03:02 AM
Rain coming in the car.. - rear passenger side. 1C00lVC E39 M5 and E52 Z8 Discussion 17 25th January 2010 12:02 AM
Passenger side foot well is 'WET'??? Shawn M5 E39 M5 and E52 Z8 Discussion 6 26th July 2006 12:00 AM
Driver-side rear footwell wet after washing car HDClown E39 M5 and E52 Z8 Discussion 7 23rd June 2005 05:05 AM
