SMG INPA clutch adaptation failure/success - BMW M5 Forum and M6 Forums
post #1 of 1 Old 1st March 2017, 09:17 PM Thread Starter
flacoramos
In summary: unless you use an external charger do not run the smg adaptation routine. My battery was 'full' and the car had sat for just an hour or so, yet it caused adaptation to fail.
Long story: was playing around with INPA last night and decided to run the full smg adaptation routine. Middle of the process got an error 'gearbox jammed or locked out' and the continuos gong and red cog. Tried to run again but got an error on the initial steps this time. Played with the pressure / bleed options and of course made things even worse.
I let the car sit for an hour, meanwhile I read a lot of similar stories in here. Was afraid I'd have something bent which would mean fix it before you can drive again. Started the car and of course no change. Tried to take it out of the garage and stalled twice as the clutch was dumped whenever I *touched* the throttle. Luckily the garage incline allowed me to get moving. When the car reached ~3mph I shifted into gear and I was able to take it for a spin. Just around the block, all in 1st gear (forget about ANY shifting). Stopped an then ran the adaptation routine and... success. What a relief to know everything was ok!
Decided to do the adaptation as shifts have been a tad rough (nothing crazy tho). Clutch may be due for a change as there's a light shuddering when taking off. Shifts are now smoother but shuddering on take off remains. Had it not been for the forum the car would be at the local dealer right now. Also read the launch counter and it's at 30. Unfortunately none of those are mine lol....
Next on the list: buy a power supply before finding an icom and attempting the smg euro tune.
flacoramos is offline
Clutch adaptation inpa robertstrendell E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 3 27th November 2015 03:57 AM
M5 inpa smg adaptation active. 4f67 bmi97 E60 M5 and E61 M5 Touring Discussion 20 23rd September 2015 11:25 PM
INPA Success - Adaptation values reset - what do you guys think desmotesta E39 M5 and E52 Z8 Discussion 98 2nd May 2015 02:39 PM
Clutch Adaptation Inpa, did it completed? Lindwallen E60 M5 and E61 M5 Touring Discussion 13 1st April 2015 11:32 AM
Clutch Adaptation thru INPA alibo70 E60 M5 and E61 M5 Touring Discussion 1 30th September 2012 10:11 AM
