3 year old fuel - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By texsn95
post #1 of 5 Old 27th February 2017, 09:30 PM Thread Starter
Jhollywood420
Jhollywood420's Avatar
3 year old fuel
What would be the best way to remove old fuel from your tank? Would it be by removing the fuel pump and pumping it our from there? Or is there a better option?
Jhollywood420 is offline
post #2 of 5 Old 27th February 2017, 10:12 PM
cold m3
cold m3's Avatar
My guess would be to pull off the quick disconnect where the fuel rail meets the fuel line coming from the tank. Its in the engine bay on the driver side back of the motor. This would require you to have the fuel pump push the fuel out which would be at 80+ psi so not sure how you would go about "catching" it safely.
Current: 6MT 2008 LCI E60 M5 (Interlagos Blue)
Last: 6MT Super Charged E46 M3 (Carbon Black) (6 years of ownership)
Instagram: Cold_M3
Photos of My ///M5
cold m3 is offline
The Following 2 Users Say Thank You to cold m3 For This Useful Post:
Jhollywood420 (1st March 2017)
post #3 of 5 Old 1st March 2017, 06:00 PM Thread Starter
Jhollywood420
Thanks for the advice
Sounds easier than removing the fuel pump. I don't how I would catch the fuel safely either. Wish I could figure it out though, because I don't want to try to remove the fuel pump if I don't have to.
post #4 of 5 Old 1st March 2017, 07:12 PM
texsn95
Like I said, you should go ahead and do the fuel filter (opposite side of fuel pump), which gives you access to the tank and takes care of a maintenance item at the same time. There's a good DIY thread on it. I wouldn't risk pushing 3 year old fuel through anything other than a hose out of my tank.
https://www.m5board.com/vbulletin/e60...-step-diy.html
texsn95 is offline
The Following 2 Users Say Thank You to texsn95 For This Useful Post:
post #5 of 5 Old 1st March 2017, 07:20 PM Thread Starter
Jhollywood420
Thanks again texsn
I will go read through the thread and start with the fuel filter. Do you know if going through the fuel fliter hole if it will give me access to both sides of the tank?
DIY: Suddenly stranded? Testing your fuel tank levels, fuel pump relay, and fuel pump in 10 minutes with a piece of copper wire JoeFromPA E39 M5 and E52 Z8 Discussion 91 11th March 2016 12:06 AM
Fuel problems year 2000 M5 Calmac35 E39 M5 and E52 Z8 Discussion 18 8th June 2015 11:39 PM
Fuel sender/fuel filter/fuel pump/ temperature gauge jack eiler E39 M5 and E52 Z8 Discussion 6 2nd May 2012 05:08 PM
Timing chain, vanos, cam gear...replacement. 6k last year.. did it myself this year. phillym5 E39 M5 and E52 Z8 Discussion 27 18th October 2008 06:46 PM
Not my year - fuel hose came of tank BlackB8 ALPINABoard.com | BMW Alpina Discussion 2 29th June 2005 09:19 PM
