Part number for the lock nuts for the cabin air filter? - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By 5soko
post #1 of 7 Old 5th November 2016, 10:13 PM Thread Starter
thefleshrocket
thefleshrocket's Avatar
I am getting ready to change the brake pads and flush the fluid on my '08 M5. I watched a Youtube video that included removing the cabin air filter cover and the other cover under it. https://www.youtube.com/watch?v=psPzkAgL2vQ So I go to remove the first bolt and can't get it to come loose. I figure someone He-manned it on, so I got my wife to hold the little bottom tab with pliers. No luck, still couldn't get the nut to come loose from the base. So finally I drilled it out.
I did the same with several other plastic nuts on the lower cover, assuming that they, too, had been overly tightened. It wasn't until I got it apart with one nut still intact that I realized that nut assembly was only supposed to turn 90 degrees so that the tab would unlock.
WELL FSCK.
Not the end of the world, but now I either need to buy some of those little plastic bolt assembly things, or two new covers. Part numbers would be much appreciated if anyone has them.
--'08 M5 - 38K miles, 6-speed, Interlagos Blue, muffler delete, RPI scoops, charcoal delete
--'04 Mustang Cobra, bolt-ons, ~460rwhp (blower upgrade and 600rwhp coming soon)
--'08 Buell 1125R, '14 Yamaha Vmax, '05 Triumph Speed Triple, '03 Suzuki DRZ-400E
thefleshrocket is offline
post #2 of 7 Old 5th November 2016, 10:14 PM Thread Starter
thefleshrocket
post #3 of 7 Old 5th November 2016, 10:44 PM
BadSeed
BadSeed is offline
The Following 2 Users Say Thank You to BadSeed For This Useful Post:
thefleshrocket (5th November 2016)
post #4 of 7 Old 5th November 2016, 11:38 PM Thread Starter
thefleshrocket
Originally Posted by IGNANT View Post
Looks like it'll only cost me a bit over $110 plus shipping for parts 02 and 03 on that schematic. Used Ebay parts are a good bit MORE expensive! The $29 new cover is going for $50 or more on Ebay, and the $83 new air inlet is $100+ on Ebay.
Thanks a ton!
post #5 of 7 Old 6th November 2016, 06:20 AM
Jomar1494
If you do a search on realoem.com you might be able to find the diagram with the part numbers. I do it all the time for all my BMW's. Works like a charm
Jomar1494 is offline
post #6 of 7 Old 6th November 2016, 01:56 PM
rt7085
rt7085's Avatar
Clutch Slave Cylinder Flush As Well?
It is probably useful to do DIY on removing the filters and bulk head. I see a lot of people not taking advantage of this, for example when they change their spark plugs and the like. However, I do not see anybody actively manage the DIY section anymore. Is @5soko able to do this?
On another note: Does anybody ever flush their clutch master/slave cylinder set when they flush their brakes? This system drafts from the same fluid reservoir. Even DIS and TIS don't mention this. Bleeding this works the same as on the brakes but of course now you would have to get under the car.
rt7085 is offline
post #7 of 7 Old 6th November 2016, 03:19 PM
5soko
5soko's Avatar
I will look into the DIY tonight and see whats there, dead links, new DIY etc. def in much need of an update
5soko is offline
E39 For Sale: Cabin Air Filter Duct (Left) for Sale wxl1988 Parts / Other For Sale or Wanted 6 7th December 2016 01:49 AM
What brand of air filter and cabin air filter? bimmerule E39 M5 and E52 Z8 Discussion 15 22nd November 2015 05:45 PM
Cabin Air Filter Replacement M5Prospect E39 M5 and E52 Z8 Discussion 13 2nd April 2015 01:58 AM
Do we really need these guys... ? Cabin filter tray part Kevin The Clean 1 E39 M5 and E52 Z8 Discussion 15 22nd August 2010 06:02 PM
changed cabin air filter...now glove box won't open roortube E34 M5 Discussion 10 1st April 2009 01:03 AM
