Rear Center Jack point - BMW M5 Forum and M6 Forums
post #1 of 6 Old 24th October 2016, 05:58 PM Thread Starter
Schaun Gallagher
Schaun Gallagher's Avatar
Hello All,
I am new to the list and a proud new owner of a '07 M5 (Black). I have researched a lot of the treads on the forum and I'm reading a lot of great information, thanks to all who have invested their time so other can learn from the forum.
I want to set my car on jack stands to do some work and regular maintenance and would like to confirm the rear center jacking point is the aluminum cross member just behind the differential cooling fins correct?
Thanks for any insight.
Regards
Schaun Gallagher is offline
post #2 of 6 Old 24th October 2016, 06:45 PM
Dacan23
Dacan23's Avatar
Thats what I use, but its not always easy to use that point depending on your jack. Also make sure the jackpad has some distance from the diff as its not touching it. Though lately I have used the side BMW special pad points when doing wheels, one side at a time, using a special adapter that fits into the hole.
2008 M5 6 Speed - Black on Black
RPI GTS Exhaust (Sec 1+2+3), Eurocharged, TMS 12.5mm Spacers, AFE Pro Dry S Drop in Filters, RPI Like Air Scoops, Black Side Vents, Smoke Side Markers, Color Matched Bumper Reflectors, Black Kidneys, Black Aluminum Pedals, Stock Wheels (Until Spring) & M6 Replicas for Winters.
2017 X5 35d MSport - Loaded no more 3rd row
2013 135i Cabrio MSport & DCT
1995 540 6 Speed
2017 i3 REX
Past Cars
2012 X5 35d Sport - Loaded
2000 Z3 2.8 Roadster M Sport 5 Speed
2011 X3 2.8i M Sport - Alpine White on Black
1995 530i Auto
1986 635CSi 5 Speed
1998 323is 5 Speed
1992 535 5 Speed
Dacan23 is offline
post #3 of 6 Old 24th October 2016, 08:25 PM Thread Starter
Schaun Gallagher
Dacan23,
Thanks. The cross member just didn't look overly robust when I crawled under the car. I have also read that I may be able to get the rear jack stand under the rear support just by jacking the car up from the front support.
New car to me means rehashing all this old news for you guys.
Thanks again.
post #4 of 6 Old 25th October 2016, 03:07 AM
rt7085
rt7085's Avatar
You need to put a piece of soft wood, like fir, under the diff itself. Not under its rear heat sink but behind it on the cast diff body, looking from the back of the car. It's a blind mate. Make sure the wood sticks out down far enough such that your jack never touches the differential heat sink. Put the jack straight under the differential. Jack up and have the stands ready on left and right. Slide them under the tire jack points when high enough. You may have to get some tick planks to drive the rear of the car onto to make enough clearance for the hydraulic jack.
Get a copy of BMW TIS software. It tells you all of this. Do not jack on any of the suspension parts or any of the frame. Bad news.
BTW: The soft wood avoids sliding because it molds under the cars weight.
rt7085 is offline
post #5 of 6 Old 25th October 2016, 04:30 AM Thread Starter
Schaun Gallagher
rt7085
Thanks, any suggestions on where to get the BMW TIS software?
Saw some on line but didn't know if the forum has a vendor.
Regards
post #6 of 6 Old 25th October 2016, 12:08 PM
rt7085
rt7085's Avatar
rt7085 is offline
Jack and jack stand point- where? SpeedAgent E60 M5 and E61 M5 Touring Discussion 34 27th March 2013 11:50 PM
Seeing front centre jack point with covers on? jamiepeers E39 M5 and E52 Z8 Discussion 13 25th February 2011 01:12 PM
Jack-point rubber pad missing Lancefitzgiben E39 M5 and E52 Z8 Discussion 3 22nd July 2007 10:03 PM
Jack Point for transmission? ECB E39 M5 and E52 Z8 Discussion 3 20th July 2006 07:52 PM
Use diff. as a jack point? ELEVENS E39 M5 and E52 Z8 Discussion 2 25th August 2003 05:58 PM
