Window regulator broke I think - Page 2 - BMW M5 Forum and M6 Forums
post #11 of 11 Old 25th October 2016, 03:49 AM Thread Starter
335xi
Thx rt, I found a screw behind the airbag emblem
Originally Posted by rt7085 View Post
Loosen the snaps with a pickle fork tool from autozone. Once all the snaps have been loosened around the bottom and sides you need to push the whole panel upwards. Don't use force! Ever! Just carefully bump up with your first/palm starting on the outside of the door. Now be careful not to pull away the panel once it loosens. There are a variety of harnesses attached. There are acrylic light pipes on the door for tray lightning: Tug on them and you risk breaking them! Once the panel is loose, first detach the door look Bowden cable. Just pull up on the plastic attachment. Then work you way around to disconnect all connectors. Some will fight you coming out of their sockets. Be patient and take you time. A little support under the panel (a box or so) could be handy to avoid strain. Remove the down light on the bottom of the panel by pulling it down and out. Do it before you loosen the panel. There is a plastic piece in the middle of the panel that is used to re-install the panel. It allows t you to hang the panel back onto the door frame. This piece usually falls off upon removal. Reinstall it. Take a close look how it all works. The snaps are not robust. Get a hand full of new once from BMW to have on hand.
That's what was holding the panel in place, it wasn't mentioned in most of the DIY youtube videos but I found one that mentioned it. That did it.
335xi is offline
changing rear window regulator but window is closed davidc E39 M5 and E52 Z8 Discussion 6 19th May 2015 03:30 AM
How To Position Side Window On Regulator? (Window Jams When Shut) Game-R E39 M5 and E52 Z8 Discussion 9 21st May 2014 04:44 AM
Window Regulator jpwrx2002 E39 M5 and E52 Z8 Discussion 12 24th December 2013 07:43 PM
Driver's window clunk/regulator problem - new regulator time? doc$holliday E39 M5 and E52 Z8 Discussion 26 8th July 2013 08:18 PM
Window Regulator DECOCQ E39 M5 and E52 Z8 Discussion 0 25th February 2010 06:11 PM
