Why I stick with 10W60 - BMW M5 Forum and M6 Forums
 5Likes
post #1 of 13 Old 10th October 2016, 11:35 PM Thread Starter
Sophie
hey guys,
I did a bit experiment by switching to Mobile One 10W40 for warmer seasons. Here is report I got from Blackstone 7500 miles later:
We had enough oil to check for fuel this time, and there was a trace amount in the sample. That does end the string of perfect reports your M5 had going, but the good news is that a trace amount is harmless, and normally just from operational factors or sampling a cold engine. Wear metals are still in decent shape. Things have been steady for the most part aside from an increase in lead. That's worth watching out for next time, but 15ppm isn't enough to show poor bearing in this type of engine. Just check back to see how things are holding up.
One thing to note is that I added 4-5 qts of oil during this span.
I was thinking of doing the bearing job after seeing the report. Then decided to switch back to 10W60 for one more time before pulling the trigger. Here is the report after 5310 miles:
Wear metals have been been excessive for this M5, but these results are downright impressive. Check out the improvements in iron and lead, lead especially. Bearing wear was creeping up last time, but no such issues here. Maybe the bearings prefer oil runs in the 5000-6000 mile range, as opposed to 7500. Since results are so good here, you might consider sticking with this interval. There is no excesss fuel this time and the air and oil filters kept silicon and insolubles low. Very nice at 95,312 miles.
I added only 1 qt of oil this time.
The test results seem to be pointing to 10W60 as a legit viable option for our car.
Sophie is offline
post #2 of 13 Old 11th October 2016, 12:14 AM
gmak
Shouldn't it be the reverse? You add the lower weight oil for the colder seasons. Also the fuel in the oil can be there from either i) injector issues; or ii) too many short trips where the car doesn't run at operating temperature long enough (have your driving habits changed for some reason?).
But that last 10W60 report sure seems to say it all, doesn't it? Could be either the weight of the oil, or the distance between changes, or both?
gmak is offline
post #3 of 13 Old 11th October 2016, 03:34 AM Thread Starter
Sophie
Hi mate,
You are right. It should have been 'warmer'. Typo
Injector is fine. Driving patterns remain pretty much the same. Both are non-factors here.
Sophie is offline
post #4 of 13 Old 11th October 2016, 04:23 AM
thefleshrocket
thefleshrocket's Avatar
I assume you meant 0w40, not 10w40?
I am about to do a 5k oil change and will be sending off the 0w40 for analysis. I have reports from PO, who used 10w60, for comparison.
--'08 M5 - 38K miles, 6-speed, Interlagos Blue, muffler delete, RPI scoops, charcoal delete
--'04 Mustang Cobra, bolt-ons, ~460rwhp (blower upgrade and 600rwhp coming soon)
--'08 Buell 1125R, '14 Yamaha Vmax, '05 Triumph Speed Triple, '03 Suzuki DRZ-400E
thefleshrocket is offline
post #5 of 13 Old 11th October 2016, 02:00 PM
nicko
With thicker oil, be sure to wait when the gauge hit 150-Farenheit before running at higher RPM, and go to Red Line only when it hits 210-Farenheit. This is a standard practice for F1 racing.
nicko is offline
post #6 of 13 Old 12th October 2016, 11:49 PM
335xi
I use 0-40 in the winter
But through out the year as the car asks for 1L, I add 10w-60. Vanos rattle has disappeared since I started doing this. There has been a lot of talk about cavitation causing the VANOS rattle and that lower weight oils cavitate more but from using my car as an experiment I'd have to say that that theory is incorrect.
p.s. I drive less than 5000/year so I only change oil once a year. I usually add 3L of 10w-60 during the year (as needed). Blackstone tests have been stellar, except for the very 1st one ( 5 years ago ) which had high lead .
335xi is offline
post #7 of 13 Old 13th October 2016, 12:06 AM
gmak
Cavitation comes from overfill and the 'addition' of air to the oil by the pump at the surface churn (I imagine). If the oil is thicker, it will not release the air as it's being circulated as well - which will lead to the cavitation (bubble bursts = not enough oil at a critical place).
gmak is offline
post #8 of 13 Old 13th October 2016, 01:43 AM
335xi
i think more bubbles = less oil
Cavitation comes from overfill and the 'addition' of air to the oil by the pump at the surface churn (I imagine). If the oil is thicker, it will not release the air as it's being circulated as well - which will lead to the cavitation (bubble bursts when oil is thinner = not enough oil at a critical place).
less bubbles means less volume occupied by air thus more oil.
335xi is offline
post #9 of 13 Old 13th October 2016, 02:09 AM
gmak
A-and..... In thinner oil, the bubbles will come out of the oil as it gets pumped. the thicker oil will hold it in much longer - so the oil gets to sensitive areas with air in it. Hence cavitation.
gmak is offline
post #10 of 13 Old 13th October 2016, 09:59 PM
Bucky
Having certain types of bound air in the air is fine in oil, like Dissolved and Foam. The bubbles in the oil are control by additives, Temp and Pressure. Change any one of them 3 and Dissolved Air then become bubbles which do harm to the engine.
Certain additives help stop dissolved air becoming bubbles.
Oils are designed to be used in a certain engine, 10-60 in the S85 because of the design of the engine. Also look at the diff oil BMW specifies. Heavyweight stuff.
I have read on the net that M-1 causes a lot of foaming. Do a search, mainly mustang 5.0 owners.
Bucky is offline
BMW M5 E60 Engine Oil: Castrol Edge 10w60 FST & Castrol Edge 10w60 TWS. Difference? Blueraj E60 M5 and E61 M5 Touring Discussion 3 31st July 2013 08:07 PM
Got Stick??? mgc9127 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 15 20th August 2011 06:15 PM
E60 Want to Buy: M5 Stick ghunte2006 Parts / Other For Sale or Wanted 2 27th January 2011 05:48 PM
Castrol TWS 10W60 motorsport VS castrol edge sport 10W60 M-POWER 77 E60 M5 and E61 M5 Touring Discussion 15 22nd October 2010 07:00 AM
TWS 10W60 vs 10W60 canysmc E60 M5 and E61 M5 Touring Discussion 25 19th February 2007 04:14 PM
