Help!!!!!! Injector Circuit Open Cylinder #9 - Page 3 - BMW M5 Forum and M6 Forums
 2Likes
post #21 of 26 Old 8th October 2016, 02:24 PM
gmak
Remove the plenum behind the engine over the DME box and brake booster to make some space
Do you mean to remove that whole plastic set up including the air filter covers?
gmak is offline
post #22 of 26 Old 8th October 2016, 02:33 PM
rt7085
rt7085's Avatar
Yes, super easy. There is a connecting piece on the middle top. It has 2 small latches you pull up and then slide it towards the DME (in the US). It pops off. Take off the air filter boxes: A plastic screw and a metal spring clip/wire across it on on both sides. Pull the clips towards the front of the engine bay. Remove the rubber seal running from left to right on then front. It simply pulls off; mind the two round snaps at the end when you place it back. Remove the two plastic trim pieces on either end covering the hood hinges. Take notice how they come out or else you will be solving a puzzle putting back in. (Take a picture). Disconnect the hood switch and smog sensor over the DME. Be careful, plastic may snap. It is a twist off for the smog sensor. Then remove the plastic screws to remove the left and right side filter boxes that funnel the air into the dash. Be careful with the plastic screws; they are fragile. Just a quarter turn. There is also a torx screw mounting to near the strut towers that has to come out. Don't drop them!. You now have the engine fully exposed in the back. You can carefully reach the two oil return hoses with your hands before you pull the plenums off the engine; key to not snapping them off (I have a stash of replacement snaps, just in case). And don't do it in winter or blow some warm air on them first. Perhaps we should do DIY; seems like a big stumbling block for many trying to do this stuff themselves. Next time I will do this, I will take pictures.
It should look like this when you are done. No need to remove the strut braces!
rt7085 is offline
post #23 of 26 Old 8th October 2016, 05:50 PM Thread Starter
//Madusa
//Madusa's Avatar
Well having proper lighting is key. I would recommend not to use an extended screw driver to try and go at loosening those hoses around the plenum. Get you a 3/8 DR Ratchet with a 10 inch extension and a number 10 socket, and it's a piece of cake removing those bad boys. If you are using a power drill instead of a ratchet, apply very little torque because you "CAN" strip the heads of those screws.
Also, to gey the little hoses off behind the plenum and at the front under them, I found it to be easiest removing these after I loosened all the throttle body hoses. There is one hose in the back, two hoses on the side towards the back, and one under the front of each plenum.
Last thing, the big hose on the side of the plenum comes off easiest with a good Ole pair off vice grips. To get the one off right behind the big one, you will need a short phillips head. Pictures below of the tools. Hope this helps!!!!!!!!
ID:	737929   Click image for larger version
//Madusa is offline
post #24 of 26 Old 8th October 2016, 06:05 PM Thread Starter
//Madusa
//Madusa's Avatar
@rt Yes, I'm going to make that a project the next. I will try and make a video along with it to share the info with everyone else. There doesn't really seem to be any good how to's or DIY on this issue.
//Madusa is offline
post #25 of 26 Old 8th October 2016, 06:32 PM
rt7085
rt7085's Avatar
The problem with the ratchet is that the socket may get stuck on the screw when you pull off/out. The socket will then fall down in the engine V (or stay on the screw). You will not enjoy that when you are in the process putting everything back on.
rt7085 is offline
post #26 of 26 Old 8th October 2016, 09:07 PM Thread Starter
//Madusa
//Madusa's Avatar
//Madusa is offline
Boom goes the dynamite...Stuck open injector/hydro-locked S85 jcolley E60 M5 and E61 M5 Touring Discussion 403 14th November 2018 04:58 PM
Can anyone help - P0204 Injector Circuit Malfunction SFTitanium5 E39 M5 and E52 Z8 Discussion 1 21st August 2015 01:06 PM
E60 For Sale: Damaged Cylinder Head Bank 1 Passenger Side - Bent Valves Cylinder 1 drZoom Parts / Other For Sale or Wanted 5 3rd November 2014 12:36 PM
P0204 - Intermittent problem - Injector Circuit Malfunction please help SFTitanium5 E39 M5 and E52 Z8 Discussion 23 13th May 2011 05:36 AM
All 4 O2 sensors show an open circuit zamir E39 M5 and E52 Z8 Discussion 20 11th March 2008 07:34 AM
