Loss of power no faults - BMW M5 Forum and M6 Forums
 2Likes
  • 1 Post By jcolley
  • 1 Post By old city bimmer
post #1 of 8 Old 1st October 2016, 10:49 AM Thread Starter
mikeeb
mikeeb's Avatar
Hi all
My S85 is causing me headaches.
It's really down on power at low revs and the power button makes next to no difference. Its dead below 6500/7000 rpm.
Only fault showing is a bank 2 O2 sensor heating circuit.
It feels like it's massively pulling the timing.
If you floor the throttle below 3k you feel it go then pull back/hesitates. It's feels ok on 1/2 throttle.
With dsc off, rolling in 1st gear @ 3k rpm on a wet road i can't provoke wheel spin!!!
I thought maybe MAF's so drove with them disconnected. It's worse.
Car is completely stock.
I'm wondering if it's VANOS related. Any ideas????
I've got inpa (It's all in German though) can I test the VANOS with inpa??
mikeeb is offline
post #2 of 8 Old 1st October 2016, 11:37 AM
ticat928
ticat928's Avatar
Bimmer logger is not expensive
you can log fuel pressure , timing , vanos angle requested, vanos angle actual and a dozen plus useful parameters.
gives a good start for chasing pure mechanical issues that do not result in codes
ticat928 is offline
post #3 of 8 Old 1st October 2016, 02:47 PM
jcolley
jcolley's Avatar
I'm going lean towards O2 sensor. The heater has to be working properly for it to read lambda correctly. The DME uses lambda to adjust fuel trim. Odds are it's adjusting the mixture improperly as a result.
Disconnecting MAFs, the engine goes into limp mode as the alphaN tables are set for a conservative, safe value.
jcolley is online now
post #4 of 8 Old 1st October 2016, 03:25 PM
gmak
BImmerlogger doesn't work with the E60 DMEs yet, IIRC.
gmak is offline
post #5 of 8 Old 1st October 2016, 03:45 PM Thread Starter
mikeeb
mikeeb's Avatar
Thanks Mr C.
I'll get the lambda changed as it's throwing a fault. It's just so down on power it feels more than that.
It's had the internal VANOS pipe replaced when did the rod bearings so I know that's ok. Is there a chance the pump is failing? Or that one of the cams has stuck in the retarded position?
mikeeb is offline
post #6 of 8 Old 3rd October 2016, 08:58 PM Thread Starter
mikeeb
mikeeb's Avatar
Well it looks like my phone app was miss-interpreting the fault. Plugged inpa in and it's a failing camshaft sensor. Which make far more sense.
mikeeb is offline
post #7 of 8 Old 3rd October 2016, 10:34 PM
old city bimmer
old city bimmer's Avatar
Good news to some degree ...I guess
"BMW 4 LIFE"
old city bimmer is offline
post #8 of 8 Old 4th October 2016, 04:11 AM
rt7085
rt7085's Avatar
I had failing camshaft sensors on my previous M5. The car drove like an new car when I replaced them. How the hell do these things deteriorate? They are simple Hall sensors. Is it the temperature or so they run too much current through these things to get sufficient voltage response. Amazing.
rt7085 is offline
At a loss with Cylinder Misfire faults...HELP GHB E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 3rd August 2015 04:19 PM
Dash lights flickered then went out, dtc, trans faults, Power steering went out... ect. phillym5 ALPINABoard.com | BMW Alpina Discussion 2 25th September 2012 03:54 AM
Im at a loss....and a power loss...Help? monsstr E39 M5 and E52 Z8 Discussion 7 8th September 2012 07:45 AM
Help: power loss - but only sometimes sunny///M5 E39 M5 and E52 Z8 Discussion 2 26th August 2008 01:35 PM
Loss of power dj leethal E34 M5 Discussion 15 6th April 2007 06:56 PM
