Urgent help please smg relay replacement? - BMW M5 Forum and M6 Forums
post #1 of 10 Old 28th September 2016, 01:53 PM Thread Starter
Craze
Hi, i ordered 2 relays from bmw oil cooler relay and smg relay.
Where can i find which is which to replace? Thanks
It looks different from diy pics im in Australia
Craze is offline
post #2 of 10 Old 28th September 2016, 02:17 PM Thread Starter
Craze
Can anyone tell me please what is top right pink relay for?
Edit i think thats secondary air pump relay correct?
Where can i find diagram (for relays please?)
Real oem drawing are different as its for usa
Craze is offline
post #3 of 10 Old 28th September 2016, 07:16 PM
M5e60_87
M5e60_87's Avatar
M5e60_87 is offline
post #4 of 10 Old 28th September 2016, 10:02 PM Thread Starter
Craze
Craze is offline
post #5 of 10 Old 28th September 2016, 10:03 PM
M5e60_87
M5e60_87's Avatar
Picture maby, but not the color. Look at the colors.
Skickat från min iPhone med Tapatalk
M5 e60 Sepang Bronze. MDM - 500 sport. 5th gear speed
M5e60_87 is offline
post #6 of 10 Old 29th September 2016, 05:33 AM Thread Starter
Craze
Hi, still not good enough, bmw supllied me smg relay and its none of the ones in the box
Where can i find or buy wiring diagram for this box and wiring harness?
I cant believe the bmw dealer cannot even provide a diagram of what relay does what
Not marked under the cover either
Whats the secret?
Craze is offline
post #7 of 10 Old 29th September 2016, 11:24 AM Thread Starter
Craze
Anyone point me to where a gnd is in the box?
Craze is offline
post #8 of 10 Old 7th October 2016, 01:02 PM Thread Starter
Craze
Ok seeing as no one had any idea and conflicting information on forums i found the following in my case:
Top left large black relay is smg relay (no contacts large terminals)
Top right pink relay is secondary air pump relay
Bottom left green is oil cooler relay
Glad i replaced smg relay, upon opening the contacts didnt look healthy
Also a fyi when i read on the forums i replaced my "pink relay" thinking it was smg relay with the incorrect smg relay bmw supplied me and a puff of smoke came out and shorted 12v to gnd. The small gnd wire burnt out
I dont think it served a real function other than a "brake" when the secondary air pump relay is off (its a no and nc relay)
I was quite panicked because bmw supplied an incorrect relay and couldnt tell me exact location of each relay other than "the box" and the mis information on the forums didnt help either
Apprently there is a pink smg relay which is dual pole, i have a feeling it may be for smg 2
anway ran new wire to earth in e box and soldered and secured to under air pump relay and all is well
Next time ill just let bmw change something like this
Craze is offline
post #9 of 10 Old 7th October 2016, 02:31 PM
gmak
Thank you for following up. Clever the way you figured it out - and those diagrams with the terminal numbers that match the relay are very interesting.
You never said what year your car was. Are the different colours for relays due to the fact that the car was made for the Australian market, or could it be a function of year? Or could it be that there are several pink relays (which I've always assumed meant SMG III)?
Still, M5e60_87's links seem to be to the point; at least by colour.
gmak is offline
post #10 of 10 Old 7th October 2016, 05:27 PM Thread Starter
Craze
Its 2005,
you can imagine how confused i was!
When the smoke came out i **** myself!
Craze is offline
DIY: SMG Pump Relay replacement Do it Yourself! cobratom E60 M5 and E61 M5 Touring Discussion 46 22nd December 2017 08:30 AM
SMG Problem: Not Relay, Not Motor, Not Pump??? 2006SunnyM5 E60 M5 and E61 M5 Touring Discussion 8 10th March 2016 05:41 AM
SMG relay location realspartan E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 27th January 2014 04:35 AM
Problem after install Angel eyes relay harness. Please help! Urgent!!! sweepy1026 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 9 25th August 2012 05:08 AM
urgent help needed! fuel pump relay or pump itself?? jonnycowboy E39 M5 and E52 Z8 Discussion 14 1st October 2009 03:58 PM
