BEWARE | RD Sport Sway Bar Failure - BMW M5 Forum and M6 Forums
 4Likes
post #1 of 21 Old 11th September 2016, 06:34 AM Thread Starter
umichchris
umichchris's Avatar
Yesterday afternoon on the way home from the office I did a simple lame change at roughly 30mph and heard a loud POP then metal scraping sounds...
My RD Sport front sway bar completely sheared through without warning.
This is a topic that's been brought up before, but I want to bring it to the forefront once more. Anyone running these should replace them immediately. I take my E60 up in the canyons, this could've happened at a VERY dangerous moment. Everyone please beware.
Swapped it out today for my OEM sways. Also, the damage was so violent that it bent my OEM end links...I'll have to replace those asap as well now.
I do custom headlights & taillights
E46 ///M3 Vert - massive overhaul/rebuild project details here
E60 ///M5 Project #Patina
E36 ///M3 (sold) 5MT sedan
umichchris is offline
post #2 of 21 Old 11th September 2016, 06:55 AM
ACG
ACG's Avatar
Sorry to hear Chris, is it in the same location as the others?
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression 5.1L Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights / Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions / CF Trunk Spoiler
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, Pearl white
ACG is offline
post #3 of 21 Old 11th September 2016, 07:02 AM
Texasgrego
Texasgrego's Avatar
We found the bar was actually coming loose. I seem to remember you also had an unknown front end noise, IIRC?
Have any more pics of the clamps and bushings? That right one is way out of place, similar.
Sway Bar Warning 2 (Too)
As many of you know we have monitoring the sway bar and surrounding components carefully in the wake of the RD sway bars breaking on several members cars.
This is what we found in looking for an "unknown noise" .
The techs that originally installed the bar became short sighted in trying to quell the squeaking, that they forgot what matters, torq. spec. and some thread lock to keep the bolts from backing out.
The top bolt of the bar mounting clamp seats directly into the bracket welded on the sub-frame (no retaining nut).
We had to bend the clamp back into a "c position", bend the high pressure hose brackets back into place, regrease, remount the sway bar from end link to end link.
THANKFULLY the top bolt was sitting loose on top of the water platter when we removed it , or I would be SOL.
If ANYONE has serviced/replaced your sway bar or any related components, I highly recommend you keep a close eye on the mounts.
Texasgrego is offline
post #4 of 21 Old 11th September 2016, 08:19 AM Thread Starter
umichchris
umichchris's Avatar
Nope, I did a front end refresh due to wheel wobble...no undiagnosed sounds. I put in new upper & lower control arms.
post #5 of 21 Old 12th September 2016, 04:43 PM
tjav8b
tjav8b is offline
post #6 of 21 Old 12th September 2016, 08:16 PM
Texasgrego
Texasgrego's Avatar
This is what i was referring to, conversation from June 1st. I had a popping noise when we discovered what's above.
Did you shorten the end links when you installed the coilovers? If not, does this not cause tension between the new link position and the static bushing?
Remember Randy had to address this.
I have asked before, is there an instance of a bar breaking on a car that was not lowered?
Glad there was no serious damage
umichchris m5board.comoholic (>1000 posts)
Sh!t ive been tracking down a popping sound in my front suspension for the better part of 6mos....ive literally replaced everything:
- upper control arms w/ new bushings
- lower control arms w/ new bushings
- say bay end links
- installed coilovers
car handles like a dream but the sound is still there. I have RD sway bars....i wonder if i should take it off & inspect it...
post #7 of 21 Old 12th September 2016, 08:23 PM Thread Starter
umichchris
umichchris's Avatar
oh ****, youre right, i do remember that now...but it turns out that the passenger side bolts were loose the brake caliper...once i tightened/torqued it back down the sound disappeared...
(also, that sound was present before lowering the car)
- say bay end links
post #8 of 21 Old 12th September 2016, 08:44 PM
Novabimmer
Novabimmer's Avatar
Damn.
So is this an inherent problem with the sway bar, or a bad batch of sway bars? Or is this caused by other factors putting unintended stresses on an otherwise good bar?
Novabimmer is offline
post #9 of 21 Old 12th September 2016, 08:56 PM Thread Starter
umichchris
umichchris's Avatar
given the multiple reports of almost exact same type of failures here as well as the same type of failures report over on the M3 Forum for the E9x series platform...it seems like RD Sport simply made an inferior product. no way these things should be snapping like that.
the real messed up part is...my car handled 100x better with that bar on than it does now with the OEM bar. feels like a totally different car and not in a good way :/
Originally Posted by Novabimmer View Post
Damn.
post #10 of 21 Old 13th September 2016, 12:19 AM
Fiftytwoeighty
Fiftytwoeighty's Avatar
@umichchris sorry to hear about your failure. Do you know how many miles you had on your RDSways?
Damn.
Quality Control went downhill -- not sure when.
I've been one of the lucky ones with my RDSways -- 53,000 miles of tracking and daily driving on my sways.
The failures are undeniable.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =162,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; MCS 2WNR motorsport coilover, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Nuke Performance fuel rail and pressure regulator, Carbon Fiber CSL intake; Lifeline Zero 360 FIA 3.0kg Novec fire suppression; Cool Shirt Pro Air/Water system; Euro RestoMod track car: caged, 6 point Schroth FIA harness, FIA Sparco Ergo & Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x9 BBS Style 42 w/Michelin Cup 2; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
Not-spec e30 racercar!!! Fully caged for wheel 2 wheel racing
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is offline
Correct sway bar bushing for 28mm Dinan front sway bar phtzer E39 M5 and E52 Z8 Discussion 4 5th August 2016 09:06 PM
RD Sport Sway Bar Settings? kendall993 E60 M5 and E61 M5 Touring Discussion 29 24th August 2015 03:19 PM
E39 For Sale: Eibach 18mm Rear Sway Bar with BeastPower Sway Bar Brackets Clemster Parts / Other For Sale or Wanted 7 16th May 2014 02:24 PM
RD Sport Sway Bar Review kendall993 E60 M5 and E61 M5 Touring Discussion 22 15th March 2012 02:53 AM
Renn-Sport Front and rear Sway Bar Impressions Bigtime007 E39 M5 and E52 Z8 Discussion 9 29th May 2003 11:29 PM
