m6 engine starting at second attempt - Page 2 - BMW M5 Forum and M6 Forums
 1Likes
LinkBack Thread Tools Rate Thread
Old 27th September 2016, 03:49 PM Thread Starter
Elie Malak
Elie Malak's Avatar
Originally Posted by jcolley View Post
What are you using to check error codes?
i usually go to my mechanic to check for codes but its a weird issue no errors on the idrive or dashboard...
it seems to happen infrequently
cold start normal nothing starts at first attempt
drive around for half and hour or so park , then go have lunch for example , come back half an hour later
turn it on cranks turns on rpm goes up to 800 then a second later, the two follwoing cases happen
1-it dies down and turns off and i turn it on second time, it turns on normally as if nothing is wrong
2-it dies down to 300 then pulls back up to 800 and stays on and everything is normal running
i dont knw why this is happening and it started about a month ago
car is driven twice a week since i have a daily toyota corolla :P
2008 Alpine White ///M6
Driven Twice A Week
A Sheer Driving Pleasure
Instagram: @elie_malak
Facebook: Elie Malak
Mods: (List Will Grow with time)
-Matt Black Grills
-Matt Back Side Grills
-CF VRS Front Lip
-CF VRS Diffuser
-VF VRS Trunk Lip
-Eisenmann Race Exhaust
-Charcoal Filter Delete
-K&N Drop In Air Filters
-Agency Power Pulley
-Eibach Lowering Springs
-VRSF Spacers 10mm Front / 12mm Rear
-FAMS Tune
-Supersprint Primary Cat Delete Bypass
-RTD Short Shifter Kit
Previous Cars:
-E60 2006 530i :'( SOLD
Elie Malak is offline
Old 27th September 2016, 04:14 PM
jcolley
jcolley's Avatar
What software is your mechanic using?
jcolley is offline
Old 27th September 2016, 05:02 PM Thread Starter
Elie Malak
Elie Malak's Avatar
Rheingold but i sitill didnt take it. To him for him to diagnose
Will go in these couple of days
Driven Twice A Week
-Matt Black Grills
-CF VRS Front Lip
-CF VRS Diffuser
-VF VRS Trunk Lip
-FAMS Tune
Previous Cars:
Old 27th September 2016, 06:00 PM
aljordan
Sounds like "vapor lock".
Old Toyotas they will raise fuel pressure to atmospheric conditions in order to quickly purge the vaporized fuel out of the lines. The cars will stumble upon a warm start due to this condition if there is an issue with the system to combat this.
aljordan is offline
Old 7th October 2016, 01:50 AM
gmak
+1 on JColley. He's your go-to guy on this. I'm about 3 - 4 years behind him, and I doubt I'll ever be where he is in detailed knowledge.
If weird stuff is happening and there are no error codes, then that is very bizarre. This car hits you, but always gives a reason.
Generally,
1. The car is either shutting off in spite of itself, or shutting down deliberately.
2. If it's deliberately, then you need to understand the startup test routine and the order, and go through that bit by bit to logically isolate the problem.
3. If it's in spite of itself - air, fuel, spark. It becomes a mechanical exercise to determine which of the three is letting down the side.
If you can get a copy of ISTA/D it will hi-light the module that is getting hit and you can dive in and see the errors, and the be walked through a test procedure. Some of the error modules are secondary. Such as the DSC error when Throttle Actuators are failing.
If you're using ISTA/D or INPA (or any of the BMW-specific software) and not getting any codes then I would say that your DME is insane.
gmak is offline
Old 7th October 2016, 01:57 AM
gmak
But OP says that he doesn't get the whoosh from the gas cap after the car has been running, which would indicate the vapour canister (? Am I getting the terminology right) and a form of vapour lock (no?) , according to RT7085.
gmak is offline
Old 7th October 2016, 03:37 AM
TJM5
TJM5's Avatar
Your CAS Module is going out. It should sit just above your right knee and has a Simmons relay soldered to the circuit board a connection in the relay is going out or the circuit board is going out due to age. It will set a code, I forget the actual code but it will refer to CAS terminal 50 the ground side of your stater. this code can only be read with ISTA/D I have an Icarley and only ISTA/D works.
That relay completes the circuit to engage the starter between ground of starter and actual ground.
Maybe its this? bad news CAS modules are 1,600 UDA and you'll need a $1,000.00 laptop to program it
'17 Raptor, Lightening Blue
'06 M5, Alpine White
'90 325i, Turbo
TJM5 is offline
Old 7th October 2016, 03:39 AM
m5 deamon
m5 deamon's Avatar
Sounds like an idle air actuator failing I had a customers car acting up start stall starts stall until you applied the gas pedal and kept her idleing then she would be fine, to eliminate the mafs unplug them and try see if she acts up
2003 M5 Carbon Black, Black sport interior.
Evolve Alpha N tune, headers,race cats,heads
Rakkiu modified throttle bodies
Schrick cams
e46 m3 oil cooler gulf oil filter housing
Kw v3 with ground control camber plates , Dinan rear sway bar, Beast power brakets
Stop tech st 40 and st22
UUC light weight flywheel 850csi clutch, Evo3 shifter and dssr
Gas mono balls
Rouge wheel studs aluminum lugs
Vorstiner front splitters
Exotics tuning finned diffuser
Euro headlights and taillights with rear fogs
Euro arm rest
40% Lock lsd
m5 deamon is offline
Old 7th October 2016, 03:40 AM
jcolley
jcolley's Avatar
I wish that were the case. I figured out how to clone a CAS into another CAS retaining all data. I have 25 of them I'd like to sell. Not a single one I've opened yet has had high resistance across the load side of the terminal 50 relay.
The codes A0C1 and A0C5 are usually relating to terminal 50 current though and not an indication of the relay itself.
jcolley is offline
Old 7th October 2016, 06:20 AM Thread Starter
Elie Malak
Elie Malak's Avatar
i dont think its the cas since y does it only do it after 30min+ of being parked and not constantly after 4 min or 10min of being parked and y is the second attempt flawless... something mechanical looks like to be the culprit .. mafs or fuel pressure regulator or relay maybe gas canister... anyways saturday i will scan it with ista and find out i still didnt scan it since i drive it twice a week and only time i can do it is saturday so no worries
gmak saturday i will find out i still didnt scan and when i said no errors i meant no errors on the dash :P
i changed both with their hoses but i forgot to change the breather valve directly sitting above them thats MIGHT be causing the idle fluctuation even after changing both.. the idle still fluctuates for 1-2min after i start it up during warm start but its something ive learned to live with to be honest.. :P
i want to finish with these issues so i can get ur tune already and those headers (inifinty design) since i was waiting for ages for headers that DONT make it sound like a v8 at low rpm.. <3
Driven Twice A Week
-Matt Black Grills
-CF VRS Front Lip
-CF VRS Diffuser
-VF VRS Trunk Lip
-FAMS Tune
Previous Cars:
Rate This Thread
Single click when starting engine. The Engineer E60 M5 and E61 M5 Touring Discussion 3 5th September 2015 01:51 PM
M5 check engine when starting the car ma143sa E60 M5 and E61 M5 Touring Discussion 0 6th April 2014 12:12 PM
Engine knock while starting?? H K E39 M5 and E52 Z8 Discussion 7 17th July 2008 08:46 AM
engine starting johnnyriz E60 M5 and E61 M5 Touring Discussion 4 11th January 2007 06:04 PM
starting the Engine on the M6! M5 Power E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 3 15th April 2006 02:57 PM
