Secondary air pump error - Page 2 - BMW M5 Forum and M6 Forums
post #11 of 17 Old 5th October 2016, 08:33 PM
jcolley
jcolley's Avatar
jcolley is offline
post #12 of 17 Old 5th October 2016, 09:15 PM Thread Starter
minim
Thank you Jcolley. Those steps looks pretty similar to the steps that ISTA-D had me go through. The fourth one what is that supposed to mean "If secondary air pump" ? I never get the MIL light showing tho and the pump is running for sure. If you look at the first picture in the test it is showing 29kg/h (first post) on the sensor and I can hear the pump starting once I start the test. However when I try to start the car with this monitor up I cannot get a reading of how much air is going there. Almost like it's disabled in some sort? Can this be coded out and thats the reason I get the message? I'd really like the system coded back in so I get it working as designed again.
Can I read out those variable names with tool32 from the MS_S65_2 ECU btw? If so I could try to arrange so I poll those values just to have a look at it. I should however figure out if the system is triggering the pump signal at all. It doesn't seem like it.
Edit: reading through the triggers for the error once more I noticed that high lambda could throw this code. It doesn't say what "high lambda" is tho. Could this be causing it maybe? Would think that it should throw some kind of code on the lambda sensors to? I know they look normal with a hot engine but I've never tried measuring during startup. I thought it would just show crappy values in the start (and that the DME didn't use lambda before the engine was at operating temperature).
Edit2: I noticed that my DME is flashed in 2013 and most of the other parts of the car is flashed back when it was new in 04-05. Could this indicate some kind of tuning software that could be the reason why this is disabled?
minim is offline
post #13 of 17 Old 18th October 2016, 02:43 PM
M5Ottawa
Secondary air system
Any more results on this ? I'm having similar code issues and wondered if you were able to track down the problem ?
Thanks,
M5Ottawa is offline
post #14 of 17 Old 19th October 2016, 01:11 AM
cold m3
cold m3's Avatar
Curious why any performance oriented driver would want a SAP in their car?
Cant wait to remove mine!
Current: 6MT 2008 LCI E60 M5 (Interlagos Blue)
Last: 6MT Super Charged E46 M3 (Carbon Black) (6 years of ownership)
Instagram: Cold_M3
Photos of My ///M5
cold m3 is offline
post #15 of 17 Old 19th October 2016, 02:33 AM
jcolley
jcolley's Avatar
Emissions compliance, that's it. There's a huge amount of real estate on the E6x M cars that could be freed up, I've been waiting for someone to ask about deleting. If you don't have a tune yet, I can disable the SAP subroutine as well as the error codes for a "off-road use" car.
jcolley is offline
post #16 of 17 Old 19th October 2016, 02:53 AM
cold m3
cold m3's Avatar
I 100% plan on removing all of it. Both pumps / all tubes and hardware. and obviously need it to be in the 'ready' state not just a CEL removal.
I want a tune for other features as well and have considered yours (FAM). Kinda waiting for the deals to show up for xmas...
Instagram: Cold_M3
Photos of My ///M5
cold m3 is offline
post #17 of 17 Old 19th October 2016, 06:16 AM Thread Starter
minim
I just assumed that it was disabled with the DME Flash that was done in 2013 and that it should be like this with the current Flash. So didn't bother more with it ^^
minim is offline
E39 For Sale: Secondary Air Pump mattmor Parts / Other For Sale or Wanted 2 4th November 2012 10:59 PM
Secondary air pump JustinM5 E39 M5 and E52 Z8 Discussion 39 13th June 2012 07:27 PM
Secondary air pump code still comes up after replacing the pump.. greekspeed E39 M5 and E52 Z8 Discussion 23 28th February 2011 02:47 PM
New pre cat 02 sensors, secondary air pump, mafs, fuel pump and filter = 1 happy S2!! madyspop E39 M5 and E52 Z8 Discussion 0 12th February 2011 04:37 AM
Troubleshooting error p0170, wrong course secondary air? flamex10 E39 M5 and E52 Z8 Discussion 3 21st November 2006 09:47 PM
