Strange SMG Problem (Skipping 6th Gear) - Page 2 - BMW M5 Forum and M6 Forums
 1Likes
post #11 of 12 Old 7th March 2017, 02:06 PM Thread Starter
Hasan Shaikh
Hasan Shaikh's Avatar
Not solved. But agree with the above post, it seems to be a heat related issue.
Is it possible that the oil cooler is blocked or not working for any reason?
Hasan Shaikh is offline
post #12 of 12 Old 7th March 2017, 03:58 PM
5soko
5soko's Avatar
Suck the fluid out of hydraulic tank and refill with fresh new fluid.. drive the car for a few mins and repeat.. try to flush some dirty fluid out of the system... see if that helps.. of course remember to bleed the block and slave cylinder when done via dis or ista.. cheap and easy try..
Next step, if the above doesnt help, would be to drop the trans and swap the shifting solenoids on the shifting block on top around and see if the issues follows that specific 6-7 solenoid to say in place of the 3-5.... If it does follow, then you know the solenoid is bad and its a, simple solenoid change and that its not the actual trans itself..
Of course after this swap, it will need a trans adaption via dis or ista..
Solenoids swap, This would be done after verifying that latest oem softwares have been flashed, smg hydraulic system has had both bleeding procedures done, trans oil fluid level is correct..
Only things i can think of to troubleshoot this before getting a new full smg hydraulic system..
5soko is offline
Strange SMG shifting problem rick504 E60 M5 and E61 M5 Touring Discussion 15 7th October 2015 01:26 AM
Smg problem! Car won't go into gear michaelsevilla E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 54 15th January 2013 11:16 PM
Strange noise in 6th Gear under 1500rpm Fulltone74 E39 M5 and E52 Z8 Discussion 25 9th December 2012 06:45 PM
Strange stumble / miss / stutter under load in 5th or 6th gear! swartzzz E39 M5 and E52 Z8 Discussion 6 6th October 2012 12:37 AM
Help! Strange noise from engine at 3000rpm in 6th gear. ryooshin E60 M5 and E61 M5 Touring Discussion 30 9th May 2010 10:02 AM
