E60 M5 @ 93k - Opinions? - BMW M5 Forum and M6 Forums
 5Likes
  • 2 Post By Fiftytwoeighty
  • 1 Post By lyallf
  • 2 Post By ACG
post #1 of 6 Old 27th July 2016, 03:20 PM Thread Starter
chrishoche
chrishoche's Avatar
Question E60 M5 @ 93k - Opinions?
I realize people really only every post the bad experiences, mostly, but I am trying to decide on purchasing an E60 M5 with 93k miles on it...
Seems like the main issues are:
1. Rod bearings - $3K - $4K
2. SMG pump - $7K
3. Throttle valve Actuators - $700 each plus lots of labor.
4. SMG clutch and flywheel - $pound of flesh.
After hearing so much about the repairs and maintenance on the SMG transmission I've decided to get a Manual 2008 with the thought that Manual won't have the SMG pump issues.
I'm hoping that the Rod bearings will show up on a history printout, unless they were done somewhere else.
Would this greatly lower the worries I should expect over an SMG?
What else should I be cautious about before buying. I have requested a full history service report from the BMW dealership so what service/preventative maintenance should I be looking to have been performed already to make sure I get to 150k miles or more?
Thanks in advance.
chrishoche is offline
post #2 of 6 Old 27th July 2016, 05:10 PM
gmak
1. Rod bearings, throttle actuators, VANOS solenoids - if any or all are done, that's very positive.
2. SMG pump - you usually only have to do the motor which is a $400 part.
3. Whether SMG or manual, you will ultimately have to replace the clutch and flywheels (and some other bits and pieces) which involves dropping the transmission.
gmak is offline
The Following User Says Thank You to gmak For This Useful Post:
lyallf (27th July 2016)
post #3 of 6 Old 27th July 2016, 11:26 PM
johnhazelwood
I have a 2010 with 86k miles on it. I had the clutch replaced, only because I was able to get my extended warranty to cover it before the warranty expired, and that's it. It's been the most reliable car I've had, coming from a 535i and 325i prior.
johnhazelwood is offline
post #4 of 6 Old 28th July 2016, 12:54 AM
Fiftytwoeighty
Fiftytwoeighty's Avatar
2007 6MT with 127,000+ miles.
Previous owner replaced the clutch at 18,000 miles. I have been on the same clutch for 109,000 miles as my track toy and daily driver.
I replaced my rod bearings at 84,000 miles as preventive maintenace.
Throttle actuators are original, VANOS solenoids are original.
All told, my ownership experience has been uneventful. Service records are essential, when it comes to buying these cars used.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =162,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; MCS 2WNR motorsport coilover, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Nuke Performance fuel rail and pressure regulator, Carbon Fiber CSL intake; Lifeline Zero 360 FIA 3.0kg Novec fire suppression; Cool Shirt Pro Air/Water system; Euro RestoMod track car: caged, 6 point Schroth FIA harness, FIA Sparco Ergo & Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x9 BBS Style 42 w/Michelin Cup 2; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
Not-spec e30 racercar!!! Fully caged for wheel 2 wheel racing
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is online now
The Following 2 Users Say Thank You to Fiftytwoeighty For This Useful Post:
Hasan Shaikh (31st July 2016)
post #5 of 6 Old 28th July 2016, 12:11 PM
lyallf
lyallf's Avatar
I hope I get that much mileage out of my original actuators and solenoids, I'm at 59000 miles. Did the bearings and needed a new SMG hydraulic unit at 57000 miles.
I wish we could all have that sort of uneventful types of M5 experience.
lyallf is offline
post #6 of 6 Old 29th July 2016, 06:57 AM
ACG
ACG's Avatar
Don't be fooled by the minority, I had my throttle actuators both replaced at 48k and last week I got the DSC message and it turns out to be a throttle actuator going out, yes it has been 70k miles since I had them replaced but nothing lasts forever. When one goes out that means the other is around the corner also.
These cars are expensive to maintain with just a simple fault to fix.
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression 5.1L Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights / Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions / CF Trunk Spoiler
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, Pearl white
ACG is offline
The Following 2 Users Say Thank You to ACG For This Useful Post:
Hasan Shaikh (31st July 2016), lyallf (29th July 2016)
E39 For Sale: Sterling/Black, 93k, nice mods, $21,000 fish30250 Cars For Sale or Wanted 16 27th July 2011 03:36 AM
E39 For Sale: 2000 BMW M5 93k miles rdudejr Cars For Sale or Wanted 1 5th July 2010 07:08 PM
E39 For Sale: Engine + headers 93k --- $6k obo Easy E Parts / Other For Sale or Wanted 9 31st December 2009 08:56 PM
Opinions: 01 M5 for Sale with 93K BMWLVR E39 M5 and E52 Z8 Discussion 25 16th February 2007 07:34 PM
2000 M5 Black/Caramel 93K miles jhowton Cars For Sale or Wanted 6 9th November 2006 04:11 AM
