E60M5 oil level conversion needed - BMW M5 Forum and M6 Forums
post #1 of 1 Old 20th July 2016, 06:50 PM Thread Starter
mfettara
mfettara's Avatar
Hello,
I have a problem reading the oil level on my 2005 (Euro 12/2004) E60M5 (with CCC and without CCC oil menu, only the dash indicator).
Issue : always displaying 1.5Lt and no orange bar = theoretically level to low
I changed the oil sensor and changed oil and filter (9.3 Lt as per service notice printed out of BMW service computer) and it did not change my problem: reading still the same and oil level correct.
Today BMW run a diagnostic test on the oil sensor which returned no fault.
Then they run a measurement that returned an oil level of 68.2mm (car idling and hot). I suppose this will equate to 9.3 Lt as I only rode about 100km since the oil change.
The diagnostic computes indicates in the comments that the engine needs a minimum of 18mm equal to 5.5 Lt to be started without damage.
As we can't figure out the reason why the sensor producing a good reading is not showing up as such on the dash indicator, I am wondering if someone here has a table that lists oil measurements in mm and the equivalent Lt volume (this way I can periodically have BMW read the level and decide if more oil is needed)?
Thanks in advance for your tips and tricks.
Cheers
Marc
Marc
2005 E60 Grey ///M5
Bikes : BMW S1000RR Track / BMW S1000R / BMW S1000XR
Previous:
99 Carbon Black ///M5
BMW K1300R / BMW K1200R
mfettara is offline
help needed with headlight conversion on m5 Ren5turbo2 Australian Forum 4 2nd April 2013 03:31 AM
oil level still showing low after oil change and 10 qts of oil supark E60 M5 and E61 M5 Touring Discussion 16 26th March 2013 06:02 AM
Oil cooler E60M5 Thackerjb E60 M5 and E61 M5 Touring Discussion 7 9th March 2013 01:38 PM
Checked oil level today -- hardly any level drop. Fulltone74 E39 M5 and E52 Z8 Discussion 7 11th May 2009 08:24 AM
[New] E39 M5 2000. Check Coolant Level and Check Oil Level sajStars E39 M5 and E52 Z8 Discussion 9 5th August 2008 03:11 PM
