advice needed - too much drone after sc :( - Page 3 - BMW M5 Forum and M6 Forums
 3Likes
post #21 of 30 Old 19th July 2016, 09:11 PM
tjav8b
My idle RPM is no different than stock. Maybe have ESS adjust your tune. I have decatted headers, no secondary catts, stock H-Pipe (you can find these cheap easily) with RPI Section 3 and it is quiet at idle.
07' M5 SILVER/BLACK
ESS VT2
tjav8b is offline
post #22 of 30 Old 19th July 2016, 09:29 PM Thread Starter
rickg
Could it be that I haven't driven the car enough to allow it to adapt hence the higher than normal idle? I think I need a resonator somewhere in the system just to take the edge of it
rickg is offline
post #23 of 30 Old 19th July 2016, 09:37 PM
tjav8b
Mine idled higher before I decatted my headers. Once I decatted my headers ESS sent me another tune and it idled perfect from then on. I also gained alot of power after the different tune. Unfortunately, ESS will not send it to you unless you specifically ask for it.
07' M5 SILVER/BLACK
ESS VT2
tjav8b is offline
post #24 of 30 Old 19th July 2016, 09:46 PM Thread Starter
rickg
rickg is offline
post #25 of 30 Old 19th July 2016, 09:49 PM
tjav8b
No. No matter how many times I asked they will not turn off the cold start. Keep saying the engine needs the extra rpm. BS...the e90s do it. I really need someone to code it out.
07' M5 SILVER/BLACK
ESS VT2
tjav8b is offline
post #26 of 30 Old 20th July 2016, 12:08 AM
randywei
Originally Posted by rickg View Post
The car has supersprint/evolve headers, race cats, unresonated x pipe and eisenmann race backboxes.
There's your problem. Add the resonator back in.
2008 Space Gray M5
Performance: Infinity Design Equal Length Long Tubular Headers (ceramic coated) | Supersprint 70mm Sec. 1 w/ Dinan 4" Resonators & 70mm Sec. 2 X-Pipe | Dinan: Free Flow Sec. 3 Mufflers, 13% Underdrive Pulley, Throttle Bodies | Evolve Eventuri Intakes | Fast Attack Motorsports AlphaN Tune | 3.91 LSD | RPI SV1 Oil Cooler
Suspension: Bilstein B16 EDC Coilovers | Dinan: FRC, CF F&R Strut Bars, Monoballs | 11" Bimmerworld Adjustable FSB End Links | RDSport RSB
Exterior: Vorsteiner: Molded 2-piece CF Splitters, CF Rear Diffuser, CF Trunk Spoiler | BMW Performance Kidney Grills | iND Painted Gloss Black Side Grills | Painted Bumper Reflectors
Interior: EuroBoutique Custom Steering Wheel | iND Alcantara E-Brake Boot | BMW Performance E-Brake Handle | Dinan Aluminum Pedals | BAVSOUND Stage One Speakers & Ghost Subwoofers
Lighting: LUX H8 160 Angel Eye LEDs | WeissLicht Smoked-out Sidemarker & License Plate LEDs | GP Thunder 45 LED Turn Signals | BMW OEM Interior LEDs
Brakes: StopTech Trophy Kit 380mm Slotted
Wheels (street): 20" HRE P43SC in Gloss Bronze 20x9"et+9, 20x10.5"et+28 w/ Michelin PS4S 255/35/20 & 295/30/20
Wheels (track): 18" HRE R40 in Brushed Titanium 18x9"et+17 w/ TMS 12.5mm spacers, 18x10.5"et+28 w/ Toyo R888 245/40/18 & 275/35/18
Misc: Hardwired V1 | Euro SMG & Custom Coding
Luxury, Class, Speed: Randy’s E60 M5
randywei is offline
post #27 of 30 Old 20th July 2016, 06:24 AM
Texasgrego
Texasgrego's Avatar
Originally Posted by Hasan Shaikh View Post
I think your drone is because of the E Race mufflers.
I agree.
The E race was engineered ( er... sorry ticat) designed to be an aggressive axle back muffler, for a then, fairly new platform.
I seldom disagree with Randy, however, I think in this case a resonated xpipe would sound less harsh, but not kill much of the E race drone do to the sheer volume of header back system.
There are many more options now, I think you can achieve better tonal balance and power throughout the rpm range by keeping your cats, non res x pipe and changing the back boxes.
You will want those cats anyhow, or your show car will stink. The worse the gas, the worse the smell. Esp. at cat heating sequence.
I absolutely love the test pipe header, secondary cat, non resonated x pipe and etronic box setup that Hasan and Imran , and you OP, helped lead me to. But not for M6, I don't think.
Amazingly little drone for amount of sound available.
Maybe in this application, Corsa is the ticket.
My .02
Your M6 is one of my favorites...
Texasgrego is offline
The Following 2 Users Say Thank You to Texasgrego For This Useful Post:
Hasan Shaikh (24th July 2016)
post #28 of 30 Old 20th July 2016, 11:52 PM Thread Starter
rickg
Right guys I've been having a little listen to the car. I've figured why I find the exhaust note so bad now, and it's because in the uk we are mostly stuck in traffic and my car idles at 1k which is a very aggressive and loud noise however sometimes the car idles at 850 (I did not have this issue before the charger)
I've pm'd member Acg but has anyone else had weird idle issues with the ess kit?
rickg is offline
post #29 of 30 Old 24th July 2016, 08:26 AM
Hasan Shaikh
Hasan Shaikh's Avatar
The RPMs will go up even you delete the cold start. I think its the auto choke or something like that.
Here is a video of my car with the cat heat delete.
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Hasan Shaikh is offline
post #30 of 30 Old 24th July 2016, 11:28 PM
ssclassa80
Drone is usually addressed with resonators by the manufacturers, oem and aftermarket
ssclassa80 is offline
advice needed.. thiknek E60 M5 and E61 M5 Touring Discussion 6 21st March 2015 08:03 AM
Advice needed please BR 549 E39 M5 and E52 Z8 Discussion 2 9th September 2009 09:28 PM
Help! Advice needed AvusAndy E60 M5 and E61 M5 Touring Discussion 4 23rd November 2008 02:14 PM
What kind of performance is needed for S38B38 to make the engine pull 400hp??? Advice is needed First e28 M5 E34 M5 Discussion 2 4th May 2008 08:50 PM
M3 Advice Needed kneedrager E39 M5 and E52 Z8 Discussion 2 20th July 2005 07:25 PM
